I have several Jacobs ball bearing chucks, 8 1/2N to 18N. I've noticed slight manufacturing differences in some of them, mostly visual stuff.
Some examples would be the way the lettering is imprinted around the top of the sleeve. Some of them look crisp and clean like they were imprinted or rolled into the sleeve. Some others look like they lettering is cast into the sleeve and the lettering is painted black. Maybe at one point Jacobs started casting the sleeves.
Also the lettering around the nose of the chuck where the key holes are. I've noticed changes in the lettering style and positions, the size or model of the chuck, drill bit size from x to x. Taper size and some also have a service kit number stamped in there.
I also have an older 16N, probably older than any of my other chucks as it came in the old style green box. On that one the key holes are drilled all the way through as opposed to the newer ones where the holes are blind. I don't like the open or through holes because it allows all kinds of small chips to get into the jaw area. Jacobs must have realized that at one point and changed the design.
Forget the new made in China ones........... The lettering is either painted or laser etched in black.
Can anyone put a approximate time frame to any of these changes ??
JL.................
JL.................
