MSC Not Carry Mobil Velocite 6, Light Spindle Oil?
I find it odd that MSC doesn't seem to carry Mobil Velocite 6, light spindle oil. There another reasonably priced source for the oil? McMaster Carr is a bit high.
Try Amazon and e-bay, also several of the members here were very helpful in finding lubes for my Cincinnati mill. You might go back and check some of those postings
olcop
The Mobil Velocite™ Oil Numbered Series oils are premium performance products primarily designed for the lubrication of high-speed spindles in machine tools. They are also used in some critical hydraulic,circulation systems and air line oilers where the appropriate viscosity grade is selected. They are formulated from select high-quality, low viscosity base oils and additives that impart good resistance to oxidation and protection from rust and corrosion. They possess very good resistance to foaming and separate readily from water.BenefitsProtection against wear.Good hydraulic performance.Resistant to oxidation and degradation products.Protection against rust and corrosion.Low spindle wear.Maintained high precision.Minimum scrap and off-sized components.Long trouble-free life.ApplicationsHigh speed spindle bearings in machine tools and equipment where high speeds and fine clearances are involved.Precision grinders, lathes, jig borers and tracer mechanisms.For sleeve type spindle bearings having greater clearances, the choice of viscosity depends on the relation between clearance and spindle speed.Low pressure hydraulic systems where appropriate viscosity is selected.For some sensitive instruments such as telescopes, laboratory equipment, etc.FeaturesGood Oxidation Resistance — Helps reduce critical deposit formation & improves oil life.Very Good Rust and Corrosion Protection — Improves equipment life & provides increased precision long-term.Effective Water Separation — Resists emulsion formation & keeps moisture out of critical lubrication areas & allows easy removal of moisture from system reservoirs.Provide exceptional lubrication of close-tolerance bearings which helps keep the bearings running cool and helps maintain the precision required by many of today's critical machine tools.Even through these oils were designed for spindle bearings, they exhibit the required properties to function as low pressure hydraulic and circulating oils as long as the proper viscosity is selected.Can help minimise inventory costs and reduce the potential for product misapplication.
Buy Mobil Velocite 6 oil for spindle bearings 5 gallon 105482. In stock ships same day. Stock distributor of Mobil, Kluber, Kyodo Yushi, THK greases and more. CNC Specialty Store 414-881-4493.
Grainger is your premier industrial supplies and equipment provider with over one million products to keep you up and running. Use Grainger.com for fast and easy ordering with next-day delivery available. Rely on our product experts for 24/7 support.
Why does Walmart show up on the list? You click on the link and it shows the product coming from a third party (Zoro). Is Walmart fronting for
Zoro now? I've seen weird stuff like this before, like Staples popping up as a source while looking for way oil.
