Just a dumb beginner question, but I just bought a small rotary table and I am sure there must be something wrong with it.
I just assumed that being a worm gear that there were no stops and that as long as you cranked the handle the table would turn. This one stops just short of one turn and then you have to crank it the other way. It will go 355 degrees and then stop.???
This can't be right can it? I also can't get it to disengage with the drive and spin freely like it is supposed to do. Should I send this thing back or is there a "trick" that I just don't know about.
Thanks for any help
Thanks for any help
