Not quite an epic tool gloat like we see here at times, but I did score these two true tenth reading 2" digital indicators the other day. They are pretty old school with the vacuum fluorescent display but one works perfectly, the other only over a bit more than 1" of range.
It turns out these have tiny actual glass scales in them. One has a crack in its scale that causes an error when you sweep past it. Works fine under that point, so I'll probably add a stop to make it a 1" indicator. Not bad for CL freebies.
