View Full Version : New Spindle for Old Walker Turner Wood Lathe, pg. 1
john hobdeclipe
12-09-2017, 09:09 PM
When I acquired a Walker Turner 12” four speed wood lathe model 5110 a couple of years ago I immediately started scheming on a replacement spindle to allow me to use 1”-8 TPI accessories instead of the 12 TPI that W T used. (I have lots of 8 TPI faceplates.)
So I set about making a spindle to fit the lathe. I decided to use the existing bearings, as they were good after being cleaned up. A spindle to use modern bearings with standard 25mm bore would also be a bit more complex, so I went with the simple solution.
I used 1026 steel DOM tubing, 1/2” bore and 1-1/8” OD. Then I essentially replicated the dimensions of the original spindle with a couple of exceptions. The main difference is that in order to cut the threads on the right hand end I needed a “runout groove” for the threading tool, so I had to increase the length of that end by about 1/4”. On the left end, instead of making the entire spindle the diameter of the bearing seat (.993"), I reduced the diameter from the end to the split ring groove to .991", to make bearing installation easier.
Keep in mind that W T used oddball bearing bores on this spindle. The right hand, double row bearing has a bore of .995”, while the left hand bearing has a .993 bore.
Here are some pix:
First, the finished spindle in front of the old one.
http://www.auldooly.com/imagehost/PC060785-17.jpg
Pressing the “abutment ring” (my terminology) up against the snap ring. With this in place, I returned to the metal lathe and took a light facing cut off of the front of the ring.
http://www.auldooly.com/imagehost/PC070791-17.jpg
Add the bearing flange, gasket, and bearing spacer, then press the double row bearing in place. I put an O ring in the thread runout groove, and it holds a 1/4” thick shaper spacer in place next to the abutment ring:
http://www.auldooly.com/imagehost/PC080792-17.jpg
After a complete trial assembly, I found that I needed to relieve both bearing flanges slightly to provide clearance:
http://www.auldooly.com/imagehost/PC080793-17.jpg
john hobdeclipe
12-09-2017, 09:11 PM
Final assembly, everything fits, and runs smoothly and quietly:
http://www.auldooly.com/imagehost/PC090794-17.jpg
And I’m ready to turn!
http://www.auldooly.com/imagehost/PC090796-17.jpg
I still need to find a couple of ball oilers, and now that the spindle is finished I’m thinking that perhaps I should strip and paint the lathe. For now the spindle still has a straight, 1/2" bore. A later project will be to bore the right end for #2 Morse Taper. I'll either do this in situ or by mounting the entire headstock assembly onto a tool & cutter grinder.
This was my first project that required machining to plus or minus a couple of tenths on the bearing seats, and I'm pleased with the results. I don't have a toolpost grinder; all of the finish diameters were done with a SHARP high speed steel bit.
I have more pix of the various operations that I can post if desired.
wdtom44
12-09-2017, 10:55 PM
Looks like a good job, and you had fun too! Yeah, I too have found you can remove very small amounts with sharp tool bits.
Illinoyance
12-09-2017, 11:17 PM
When I rebuilt my WT lathe I was not making the spindle so I spent the big bucks for the special bearings. In hindsight I would have been better off to make a new spindle that would allow the use of standard 1" bore bearings.
Alistair Hosie
12-10-2017, 03:59 PM
When you went that far did you not fit a new belt and some people even add a spare and tape it on theinside out of the way. I would hate to have to exchange my flat belt on my metal lathe it is actually done in situ and you need a special clamping jig easilly shop made.Howevery time I tried to make a new belt it always broke within seconds LOL not doing something correct eh? LOL alistair
john hobdeclipe
12-10-2017, 07:42 PM
When you went that far did you not fit a new belt...
When I first bought the lathe the belt on it was trashed, so I installed this new one. It only has about 4 or 5 hours of running on it. Replacing the belt on this machine is easy and simple, once you know which way the spindle comes out!
