View Full Version : Pics..Fitted table power feed
Allan Waterfall
08-24-2004, 03:42 PM
Finally fited table power feed,the adapter slides over the existing lead screw and is fastened with a pad bolt.
I fitted a ballrace as I had one spare and it saved turning a bush.
Still got the stop switch to fit.I'm trying to do everything without altering the original parts.The stop switch will probably be on a bracket fastened on the gib adjusting screws.
Adapter turned from 1" sq.
http://img.photobucket.com/albums/v214/Greenlathe/Tom%20Senior/Components.jpg
Fitted
http://img.photobucket.com/albums/v214/Greenlathe/Tom%20Senior/2Fitted.jpg
Allan
bernie
08-24-2004, 04:14 PM
Very nice job Allan. Nice when you can keep original parts un-modified.
spkrman15
08-24-2004, 06:42 PM
Nice Allan,
Good pictures, nice description. Very well done.
Rob http://bbs.homeshopmachinist.net//smile.gif
Paul Gauthier
08-25-2004, 11:24 AM
Nice neat application. Well done
Paul G.
08-25-2004, 09:01 PM
Good job,darn it,I need to retire http://bbs.homeshopmachinist.net//biggrin.gif
PSD KEN
08-25-2004, 09:40 PM
Excellent in all respects!
L6steel
08-25-2004, 10:11 PM
Thanks for posting the information, Alan!
This is a project that I'm planning on doing in the near future.
What does the allen bolt in the square section of the arbor do? Is it a set screw?
Is the motor a stepper motor? I've seen lot's of those for sale on Ebay and often wondered if they work in such an application.
Thanks and take care!!
Michael
Michael Az
08-25-2004, 10:42 PM
Nice work Allen. What kind of mill is it and table size?
Michael
Allan Waterfall
08-26-2004, 04:43 AM
Reply to both Michaels....
The allen bolt in the square section tightens the brass pad bolt to grip the existing lead screw,better than a grub screw and doesn't mark the end of the lead screw.
The square section was drilled for the brass before boring for the lead screw,the brass was left with a small shoulder at one end and pulled tight with the allen bolt and then the lead screw hole was bored. Remove brass,cut shoulder off and cut in half at the high point of the arc bored,threads in one half only,bolt clearance in the other.
The unit is a bought table power feed.
The mill is a "Tom Senior" Light Vertical made in 1975,ex school machine,bought it off ebay,table is about 26"x 6",total traverse is approx 17"x 5"
Allan
