Clystal clear thick oil recomendations?
  • Edwin Dirnbeck
    • Feb 2011
    • 1177
    My home shop 13 inch GEARHEAD lathe drools oil out of multiple places on the headstock.I am NOT GOING TO FIX IT.It looses maybe quart or so in a year.Typical thick oils leave a bad brown stain on everything .I would like a thick crystal clear oil. This is a light duty machine and I am not looking for the perfect oil. Good enough is fine.Edwin Dirnbeck
  • 3 Phase Lightbulb
    #2
    Do you really think crystal clear oil going in is going to come out crystal clear? Oh boy...
    • JoeLee
      • Aug 2009
      • 10873
      #3
      Glycerin is crystal clear but I don't know how good of a lubricant it would be.
      JL.....
      • BCRider
        • Dec 2015
        • 11596
        #4
        The Castrol 10Wt non detergent oil I got for my head stock bearings is darn close to clear. What oil weight does your manual call for?
        Chilliwack BC, Canada
        • grim_d
          Member
          • Aug 2016
          • 50
          #5
          If you are not going to fix it does it really matter if it leaves stains?
          Make chips, worry not about oil stains.
          • 3 Phase Lightbulb
            #6
            Maybe his shop is in the bedroom?
            • Michael Edwards
              • Aug 2007
              • 932
              #7
              paint your lathe brown
              • MattiJ
                • Dec 2016
                • 4916
                #8
                Baby oil
                For tapping and rust-proofing try lanolin nipple cream
                • 3 Phase Lightbulb
                  #9
                  How about getting a diaper for the lathe.
                  • Rich Carlstedt
                    • Jul 2001
                    • 5497
                    #10
                    Ed, The oil that stains has got sulfur in it , which is used as a non-galling aditive.
                    What you want is 20 Wt non-detergent oil.
                    Our farm supply here sold it in quarts for many years and it was clear.
                    I use it in my 12 inch Clausing Lathe
                    Now, they only have 5 gallon containers .
                    You may also want to look at Hydraulic Oils in 20 Wt
                    Rich
                    Green Bay, WI
                    • boslab
                      • Dec 2007
                      • 8868
                      #11
                      The only one I know is Edwards vacuum oil I used to use in the spectrometer pumps in work, spendy stuff but it was clear mineral oil, can't remember the properties so it may be entirely unsuitable
                      Mark
                      • 3 Phase Lightbulb
                        #12
                        WD40 would be great, but he did ask for something thick. Maybe mix up some WD40 and starch.
                        • dbq49er
                          Member
                          • Jan 2017
                          • 83
                          #13
                          Go to an oil supplier and get ISO 68 oil. This will be what most call SAE 20 weight non detergent oil. I had to buy the 5 gallon size. If it leaks that much you will use it up eventually. DO NOT use a car oil! It is a clear/light 3 in 1 color.
                          DBQ49er
                          • CCWKen
                            • Jan 2003
                            • 8567
                            #14
                            Tractor hydraulic oil is clear. Good for seals, bearings and gears.
                            • Duffy
                              • Jul 2007
                              • 1784
                              #15
                              Mineral oil from your local drug store is pretty clear.
                              Duffy, Gatineau, Quebec
