Hello,
I recently purchased a Logan 14” lathe. It needs several parts. The main thing is the pulley that goes on the motor is missing. I’m planning on building one but I need the outside diameter of the pulley. I can figure out the rest of the dimensions. It is the variable speed pulley with the flat bottom. If someone has one I would sure like the info.
Thanks
Barry
Thanks
Barry
