I've got a Syncrowave 350 LX at my house, setup to run on 240 VAC split-phase. Long story short, I've got a second location I'd like to be able to run my welder but this location only has 208 Y service available. The 350 LX has a max output of 400 amps but I can't see ever running it at more than 150 amps at the second location.
You reckon I would damage any of the internal electronics if I fed it with 208 two-phase? The long term solution is to get a 3-phase to split phase transformer but I need to do some welding next weekend and don't have time to source a xformer and get it installed by then.
(I'm make a distinction between "split-phase", 240 VAC service and "dual phase" 208 VAC service where dual phase is meant to mean two phases of the 3 phase service)
