Got a lot of general metal shop time with hand tools & drill press, but have a new Enco mill-drill and am still learning (and having a blast). I've been struggling with this, thinking I ought to be able to figure it out, but I'm too old to waste time anymore, so here's my dumb question:
I'm just trying to take an accurate depth cut off the top of a piece of (flat) stock held securely in a milling vice. To set the depth of the cut, I'd run the tool down until it touches the workpiece (more later), set the downfeed dial to zero, move off the workpiece, dial in the depth of the cut, lock the quill and then mill-on. Got very poor results - mostly a deeper than expected cut by up to almost 10 thou.
At first I thought that there was axial play between the spindle and the quill. There was a little and I adjusted this out to less than .0005" - about as low as I can go without the bearings starting to get warm. This essentially had no effect on cut accuracy.
Finally I noticed (DUH!) that between when the end mill first touches the workpiece and when all the backlash is out of the quill downfeed is (guessing) several hundreths. So I tried lowering the tool down VERY firmly against the work to set the zero and then after I set the cut depth, press up on the tool with a piece of oak to take out the play while I lock the quill. This gets better results but still several thou of inconsistency. Most of all, this seems really awkward and I just don't ever remember seeing a machinist go through these contortions to set up a cut.
So hat in hand, I ask you all what the heck's the real way to set up a cut depth?
P.S. With my new found humility I might as well go ahead and ask what's a good book to learn this and other similar basic machining techniques?
Thanks,
Jay McMullan
Atlanta & Savannah GA
BTW, if ibewgypsy takes a look at this - drove through Tunnel Hill a few weeks ago on the way back from Jack's River. Really pretty country up there!
Thanks,
Jay McMullan
