View Full Version : Bridgeport J-Head Pulley Belt Size?
CCWKen
05-10-2018, 03:43 PM
I'm having trouble getting the belt down on the lower two pulley steps. There's not enough slack in the adjustment. When I select one of the top two steps, the tension bolt barely moves back--There's about one inch of the slot still showing. Seems like the belt should be 1/4-1/2" longer.
Also, has anyone used a link belt on the Bridgeport?
CCWKen
05-10-2018, 04:08 PM
Found a BP belt on Amazon. It says the length is 34 5/8".
JoeLee
05-10-2018, 04:57 PM
Found some notes when I inquired about one.
1 1/2" x 35 1/2" 72 degrees. PN#1-18-2120 2J868 46.
Some people use snowmobile belts but I think they are a lot stiffer and may have a different angle.
JL.............
CCWKen
05-10-2018, 07:24 PM
1 1/2" x 35 1/2" ? :confused:
That doesn't sound like the step pulley belt. :D
Ohio Mike
05-10-2018, 09:48 PM
My step pulley J head has a 4L340 belt (that's 1/2" x 34" long)
RichR
05-10-2018, 10:26 PM
The leading 1 is probably the quantity.
JoeLee
05-10-2018, 10:47 PM
I thought we were talking about a belt for a variable speed head.
JL...............
CCWKen
05-11-2018, 07:52 AM
Ya gotta read beyond the title. :D
jmm03
05-11-2018, 08:12 AM
ditto on the 4L340.
