update on radial engine
Sid,
It looks Great. Do you have a build post here on this or will you be posting a link to a off site posting, because it would be great to see the work, time and steps it took to get this done. How about an article for the HSM, I'm sure George would publish it!
Anyway, Thanks for sharing.
TX
Mr fixit for the family
Chris
TX
Chris
Sid
Sid, are you planning for safety wire for the prop hub screws? Would add an authentic touch. The stainless bolt heads could be cross-drilled to accept the wire. Looks like a couple of them are loose. Otherwise, a great project.Weston Bye - Author, The Mechatronist column, Digital Machinist magazine
Originally posted by Weston Bye View PostSid, are you planning for safety wire for the prop hub screws? Would add an authentic touch. The stainless bolt heads could be cross-drilled to accept the wire. Looks like a couple of them are loose. Otherwise, a great project.
Originally posted by sid pileski View PostWes- I agree safety wire would look great. Those are #2s. Might be a bit of a challenge!Weston Bye - Author, The Mechatronist column, Digital Machinist magazine
Originally posted by mixdenny View PostI Like the double sided, high density diskettes! Haven't see those in a while. Very clean design. What does the copper tubing ring do?
Dennis
The copper ring is he intake manifold for the cylinders.
Sid
Originally posted by 3 Phase Lightbulb View PostHow are you liking your Grizzly 96" tool chest..... youssuunavvaaaguun..
Edit: why did you cut the prop?
The look I was going for is the engine on a test stand. I just happened to find that prop at my local hobby shop, and it was to large in diameter to clear the table. I may shorten it even more to make it look like a test prop ("club prop")
Sid
