I've seen some of those videos showing how a coating repels water so strongly that virtually no liquid will remain on it. I have one of the kits but haven't used it yet. I'm wondering how well it would work as a release agent for casting resins- anybody have any experience with that? Seems to me it would be a sort of semi-permanent anti-stick surface. Either the unhardened but catalyzed resin would react with it to form the toughest glue known to man, or it would work as slick as snot as a mold release.
Lately I've been experimenting with snow slider material as a mold material. I heat-form it and cast resin into it, and it then releases reasonably well with no damage to either surface. But heat forming it is an imperfect science, at least in my home shop, and I want something that works slicker than that. I can spin-cast the shapes I need using finishing epoxy resin, which leaves the desired 'optically smooth' surface, but still requires a mold release agent to be applied. Regular mold release works ok but takes some finesse to get a really smooth and streak-free surface out of it. I want to skip this step if I can.
I know I'll end up doing the experiment with the hygroscopic coating (NeverWet I think is the name for the stuff I have). Just wondering if anybody has tried this-
