I thought I would start a new thread from my purchase advise thread as I now have a PM1228. In that thread I discussed a problem with the power feed, found a broken part and documented how I repaired it. In the process of repairing I saw something that seemed odd. It took a few days to register but now I'm asking myself... was that right?
Issue 1
While repairing my power feed issue, I pulled the saddle and the apron off of the machine. While cleaning and reassembling I found that the V-section on the underside of the saddle that mates with the V section of the ways was gouged. By gouged, I mean it looked like someone took an angle grinder and dabbed their way along the surface that presumably slides on the way closest to the operator leaving perhaps only 1/2" at either end "fairly" untouched. Deep dabs/gouges and no attempt to smooth them and make a continuous surface. At first I thought it was something done at the factory for whatever reason but a few day later I found similar gouge marks on a bit of tooling that I know was not factory. I believe the original owner did this but don't know why. The V portion of the ways look pristine, not scratched or dinged up so this gouging isn't affecting it.
Any ideas as to what's up with that? Should I be concerned? Is there a way to repair it?
Second issue: Gear noise while running in reverse spindle (not left handed threading)
I don't have it mounted to a bench yet but I was able to power it up and run the various gears etc. to test the power feed and threading that I worked on. I found that the external gear train was distinctly noisier when running with a reverse spindle direction. The sound was periodic, repetitive, and sounded like a meshing issue. If I take it out of gear the noise stops.
Is this normal? Or should I go through that geartrain, clean, lube, and check all of the meshing?
thanks.
steve
Issue 1
thanks.
steve
