The thread on what oil for quenching got me thinking about this. I have intended for some time now to build a bit of a paint booth with hood, exhaust fans, and potentially some long sleeved gloves through the front so you can manipulate things inside with the front door closed. It occurs to me now that this booth could accommodate other gas-producing operations such as silver soldering, liquid plastic resin molding, heat treating, etc.
One concern I have is that combining flame-using operations and recently sprayed paint might be seen to be risky- though using common sense would make this a non-issue. You wouldn't go directly from a recent painting job to a flame polishing job, for instance.
In any case, the base size for my booth is already set because it's a bench top set at 34 inches above the floor. It's 34 inches deep and 52 inches wide. It centers below a window which I'll take out and replace with a vent fan system. Part of that system will suck fumes directly from the surface of the bench in case heavier than air gasses collect there. The bench will be surrounded by walls, a top, a front header and maybe a bit of an sill- and have doors with windows. This will all be made from 1-1/2 thick iso foam board, including the back wall. Perhaps I should face the inside with foil-
The bench will have a turntable in it, to which I could attach any kind of work-holding jig. I want to be able to rotate that with a foot pedal, and I think it might be good if it's not fixed in one position on the bench. This alone would be an HSM project.
Still wondering how to do the doors. I'm thinking three parts, two that are narrower and sit to the left and right sides of the bench. A central door would be just the right width so you could work without it in place much of the time and still get decent fume extraction. That's kind of what I'm trying to figure out right now, the right opening so I can still work easily in front of the bench and not have to have the fans at full tilt all the time.
I could make it a single lift-out door- it would not be heavy and I could just lean it against a wall when not using it. But I think with a full-wide front opening I'd be risking having some fumage coming into the room. Maybe this is something I experiment with once all the other constructions are done.
