I'm trying to avoid repainting my front door (it is gloss black). The door faces S.E. so it gets pretty intense morning sun here in SoCal, which is hard on the paint. So I am thinking of getting a steel clad door and having it powder coated. The offering from HD spec's galvanized and primed. Simply powder coating over this would be ideal. If the primer must go, ok, but if galvanizing is a problem...?
OT Powder Coating Question
I think that most metal doors are styrofoam filled. That might not work so well in the powder coat oven where it reaches around 400 degrees F.
BrianOPEN EYES, OPEN EARS, OPEN MIND
Well yes, steel dents. But fiberglass cracks.
Both are bad. Both are repairable.
Originally posted by Bob Engelhardt View PostSteel doors get dents in them. Fiberglas doesn't.Paul A.
s
Golden Triangle, SE Texas
Originally posted by bborr01 View PostI think that most metal doors are styrofoam filled. That might not work so well in the powder coat oven where it reaches around 400 degrees F.
if I recall correctly, powder coating requires bare metal. So, both primed and galvanized would be a problem. Unless the galvanized is the non-oil type (aka Paintgrip) the powder coat would have adherence issues.Finding creative ways to turn material into scrap for decades.
Current Machines:
South Bend 13” Lathe (being rebuilt)
Bridgeport Mill (step pully J)
Garvin 2A horizontal mill
Ohio 20” shaper
Harbor Freight 4x6 band saw
All steel doors are NOT foam filled. Many commercial-grade fire-rated doors have a fiber 'honeycomb' that separates the two steel sides, and provides some insulation. Most of these have a 3hr fire rating and they may well hold up to powdercoating. You'd need to check with the mfr.Southwest Utah
