pgp001
09-17-2004, 03:31 AM
I thought some of you might be interested in the mods I have done to two of my dividing/indexing heads.
The spindle of the larger Tom Senior one was originally made to accept a chuck and had a 2 morse taper bore. The smaller one had an unidentified collet bore. I have made a new spindle for each one to accept collets which I already had full sets of.
The first and second photo's show the set up for producing the outside taper on the spindle, the cut is from left to right so there is no backlash in the cross slide.
The taper bore had already been finished in the Harrison lathe, and a piece of centre drilled ground bar was gripped in one of its own collets, this ensured everything was running dead true.
http://homepage.ntlworld.com/phil.procter/Indexer%20Heads/turning%20taper%20on %20myford%2001.jpg (http://homepage.ntlworld.com/phil.procter/Indexer%20Heads/turning%20taper%20on%20myford%2001.jpg)
http://homepage.ntlworld.com/phil.procter/Indexer%20Heads/turning%20taper%20on %20myford%2002.jpg (http://homepage.ntlworld.com/phil.procter/Indexer%20Heads/turning%20taper%20on%20myford%2002.jpg)
This photo shows the new spindle and collet, together with the original one.
http://homepage.ntlworld.com/phil.procter/Indexer%20Heads/new%20and%20old%20together.j pg (http://homepage.ntlworld.com/phil.procter/Indexer%20Heads/new%20and%20old%20together.jpg)
This is the Tom Senior head with its new spindle installed, I will make an adapter to allow a chuck or faceplate to be used as well. The worm and dividing plates are easily removed for simple indexing on these heads.
http://homepage.ntlworld.com/phil.procter/Indexer%20Heads/spindle%20fitted% 20in%20larger%20head.jpg (http://homepage.ntlworld.com/phil.procter/Indexer%20Heads/spindle%20fitted%20in%20larger%20head.jpg)
This photo shows the smaller head with a similar spindle to take Bristol Erikson DA180 collets, it is very compact and light, and is ideal for quick and regular use, I get fed up heaving 30lb units onto the table every time I need to use them.
http://homepage.ntlworld.com/phil.procter/Indexer%20Heads/spindle%20fitted %20in%20smaller%20head.jpg (http://homepage.ntlworld.com/phil.procter/Indexer%20Heads/spindle%20fitted%20in%20smaller%20head.jpg)
I have also made a packer for the small head, so that the tailstock from the Senior can be used with it if required.
Phil (UK)
[This message has been edited by pgp001 (edited 09-17-2004).]
Phil (UK)
