View Full Version : Replacement Bezels
Tungsten dipper
02-12-2019, 01:21 PM
Where can I get replacement bezels for dial indicators and test indicators?
BCRider
02-12-2019, 01:43 PM
Those are going to be specific to the make and model of the indicator.
If it's one of the major names and the outfit is still in business I'd contact the company via email asking about parts. Even if it's not obvious which address to send it to I'm sure it'll be forwarded within the company to the right place.
If it's a cheap Asian indicator or from an outfit long out of business then you're out of luck. Just buy a whole new indicator or get creative and make your own. If it's got a domed crystal and won't take a flat replacement you might be able to buy a domed crystal from a major name source and adapt the bezel design to fit the different crystal diameter. Or maybe you can trim the diameter if it's too large.
Toolguy
02-12-2019, 02:06 PM
All you ever wanted to know about dial test indicators -
http://www.longislandindicator.com/p37.html
umahunter
02-12-2019, 05:30 PM
Depending what brand long island like stated and some can be found on ebay I found one for an indicator I got on Craigslist with a broken bezel
Mr Fixit
02-12-2019, 07:00 PM
You might check out your local watch repair shop, not the mall places but the real deal in a brick and mortar shop. They probably can get one for a pocket watch or like that would maybe fit.
TX
Mr fixit for the family
Chris :)
Tungsten dipper
02-12-2019, 07:06 PM
Looking for a 55mm bezel for a 70's Fowler 1" dial indicator.
Thanks for the replies!!
reggie_obe
02-12-2019, 07:57 PM
Maybe here: http://www.fowlerprecision.com/Products/Machinist-Grade-Dial-Calipers/Fowler-Machinist-Grade-Dial-Calipers-Medium-Bezel-and-Crystal-BC2-05-100-068-0.html
Tungsten dipper
02-12-2019, 08:14 PM
too small. Thanks though.
reggie_obe
02-12-2019, 09:26 PM
They have an 800 number, wouldn't hurt to call he parts department and ask.
Bob Engelhardt
02-13-2019, 09:59 AM
To be clear: the "bezel" is the ring that holds the crystal in place. You need the bezel & not the crystal? It's usually the crystal that needs to be replaced.
Tungsten dipper
02-13-2019, 10:16 AM
Your right I need a crystal. Thank you. I'd take both if I could find one. The problem is the bezel/crystal will cost more than an import indicator.
JoeLee
02-13-2019, 10:35 AM
This place here may be of some help to you http://www.longislandindicator.com/
But with all the different makes and styles out there nothing is going to be standard fit. Too many different sizes, mountings and retainers etc.
If it were me I would go to the original mfg. for exact parts.
JL.............
Tungsten dipper
02-13-2019, 11:15 AM
JL.............
I have and they don't show any on their site. It's too old. Works great though.
ken
02-13-2019, 11:58 AM
This guy is not far from me and I have bought some Bezels for Mitutoyo indicators from him they are very will made I don't think you you could buy just the crystal for what he gets for the hole thing. Ken https://www.ebay.com/itm/New-bezel-with-lens-only-for-mitutoyo-dial-indicator-made-in-USA/122725095513?hash=item1c92fc5859:g:39sAAOSwx2dYG9O 1:sc:USPSFirstClass!98674!US!-1:rk:3:pf:0
Bob Engelhardt
02-13-2019, 12:33 PM
I have made a new crystal. There are a variety of videos/sites/forum posts on how to do it. Most of them talk about how to create the dome by heating or some such. I couldn't get any of that to work. Finally I found instructions that worked. It was simply a matter of cutting the blank just a tiny bit bigger than the bezel and then forcing it in. Which caused it to dome!
I used 0.040" polycarbonate that I got at a hobby shop. I had various PC in my pile, but none that thin.
lynnl
02-13-2019, 02:00 PM
At times I've gotten items in clear plastic packaging that was pretty stiff and thick. I've often wondered if that stuff couldn't be adapted to such uses as crystals. i.e. a "poor man's crystal"
old mart
02-13-2019, 02:23 PM
To fit the "glass" into the bezel, you would find this type of press invaluable. https://www.ebay.co.uk/itm/13Packs-Watch-Back-Case-Press-Opener-Crystal-Glass-Closer-Fitting-Repair-Tool/173387268564?epid=28021057368&hash=item285eafc1d4:g:wsEAAOSwCLNbN41J:rk:1:pf:1
Tungsten dipper
02-13-2019, 03:15 PM
Called Fowler; their parts catalog only goes back to 1996, so this nice man, told me I was out of luck and then he offer a discount on a new indicator.
I have 5 or 6 indicators so I may try your suggestions in build one. If not, I have plenty of spares.
Tungsten dipper
02-13-2019, 03:30 PM
Here’s a question. Would you part out a newly sealed Chinese made indicator (1” to 2”) for a for the crystal (Have 2 of them new in boxes) to put in a Japanese made Fowler (1”) made in the 70’s?
https://uploads.tapatalk-cdn.com/20190213/3e202843f57d2cdf95b53069de1b88f1.jpg
JoeLee
02-13-2019, 10:13 PM
That could be a tough call. Depends on what the Chinese one costs, how accurate it is and what you think the life expectancy of it is.
With out a doubt the Fowler is much better quality.
JL.................
