I dug out some brazed carbide lathe tools I bought some time ago to try on aluminum. These were C2 uncoated knife tools. Big lump of rubber gooped on the end over the carbide for shipment. Peeling off the rubber revealed a nice sharp carbide tool. I tried a few 10 thou cuts on round aluminum bar stock and noticed that aluminum was packing up on the tips of the carbide. Noticeable bump you can feel with your thumb. I have had saw blades build up aluminum deposits when cutting round stock. I was told to machine aluminum dry with carbide but there is just too much build up of metal on the carbide tip. Is there a solution to this? Should it be flooded for machining?
Don
Don
