View Full Version : anyone make jewelry?
Samuel
08-17-2001, 04:57 AM
here is a ring that I turned from stainless and then formed. http://tsukamakishi.com/stainlessring.html
Samuel
Tony
09-25-2004, 02:26 AM
morning gang,
got it in my head to try to make a piece of jewelry... specifically, a ring. (i have a lathe http://bbs.homeshopmachinist.net//smile.gif ... now i've never made jewelry before and was hoping for some suggestions.
all i can think of is: turning and buffing some nice material. at most i could cut some fine grooves in it and rub a crayon in there for excitement.
but every ring design i think of, ends up looking like a wedding/engagement ring. and thats the last message i wanna send!
anyone ever make a ring that didnt look like a wedding band? or have any ideas? i have a lathe and a mill. oh, and a few welders too http://bbs.homeshopmachinist.net//smile.gif
-tony
jfsmith
09-25-2004, 06:50 AM
Tony,
Try making the ring wide and to fit the middle finger, thats a cocktail ring. You can make them from 304 stainless to be on the less expensive side or from Palladium if you want to be on the expensive side.
Remember these metal don't have the malleability of gold or other soft metals, so you may have to cut them in the back for expansion.
I have make lots of rings, they aren't that hard sometimes it's the polishing work that take all of the time.
Jerry
tenfingers
09-25-2004, 11:17 AM
Tony,
I made a ring a while back when I came home without a birthday present for my wife and needed something quick.
While I was cutting it off (before I learned to keep the gibs tight and surface speeds low), the cut-off tool chattered and I noticed it made an interesting surface. So I made a ring with two smooth sides and a rough chattered groove in the middle. My wife actually liked it.
10F
ibewgypsie
09-25-2004, 11:30 AM
I learned to cast by casting jewerly.
I'd carve it in wax, pour investment around it and cast.
I have made rings from blocks w/my mill. I made a large "T" ring for a local biker. I wondered why he wanted a single initial, then I saw the branded drunk with the large "T" red mark on his forehead.
Milling ? What comes to mind is my cnc w/joystick.. Carving with a 2hp dremel tool?
David Cofer, Of:
Tunnel Hill, North Georgia
[This message has been edited by ibewgypsie (edited 09-25-2004).]
x39
09-25-2004, 06:12 PM
I've made several belt buckles, also did a set of wedding bands out of a piece of Aquamet stainless propellor shaft for a commercial fisherman and his fiance.
gunsmith
09-25-2004, 06:26 PM
Try this. Cut your ring to the desired shape and rough in your finish. Stainless is the best to start with because of the variety of finishes it takes, satin to high polish. Then with a grooving cutter or hack saw cut a couple of parallel or diagonal groves across the crown to a depth of about 1/3rd of the crown. Take some ordinary brass, copper, plastic of any color or sea shell and with care cut it to the rough snug but not bullet tight shape of the groove. Leave a little overhang on the ends and top. With the best grade epoxy glue your slugs in place in the grooves you cut. With a file bring them down to the shape of the ring and then carfuly pollish them. Most things can be polished with rough. Polish slowly so you don't overheat the ring and cause the epoxy to let go. You will be amazed at how nice this simple insert, contrast and looks.
ibewgypsie
09-25-2004, 07:06 PM
The same kind of negative masking w/photo resist works well.
I saw some rings made by a friend of mine, they were about 1/16th deep etching.
You can purchase the photo-resist chemicals from any circuit board supply company. It does open up a whole new world..
Etching deep into aluminum for legend plates, is a neat selling item. It pays pretty well and not hardly anyone is doing it anymore.
THIS is how they make printing plates of counterfeiters of old. It is amazing the detail you can capture.
HTRN
09-25-2004, 07:33 PM
David, Radio shack sells a kit to do circuit etching: http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&product%5Fid=276-1576 for those who want to try it out. The interesting thing is that the so called resist ink pen appears to be nothing more than an ordinary Sharpie! I've heard that with an inkjet printer you can print out the image you want(mirrored, for obvious reasons), place the sheet of paper on the plate and using a hot iron, transfer the image to the plate. You then go and touch it up with a sharpie and dunk it in the chemistry. Wala! instant art! I thought about doing portraits using Corelphotopaint to convert Jpeg photos to a sketch, and do the above in aluminum and copper sheet... As for making jewelry, I was involved in a shop clean out in a Bronx High school that had among other things, a spin caster. I didn't get it, but did manage to snag a couple of books on jewelry casting. To those who want to get into it, a spin caster can be had from Ebay fairly cheap and gold can be melted with an OxyAcytl. set up. You can purchase wax ring blanks from a variety of sources and once you have the pattern, you can make it over and over again. I wanted to get into it, as NY is a huge Jewelry market, particularly for custom stuff, but it's a hard racket to get into...
HTRN
ibewgypsie
09-25-2004, 09:09 PM
http://www.hosfelt.com/ click on "photo-etch" on the menu on the left..
You spray the photo-resist on there out of the pump bottle, let it dry in the dark, place your negative on top of it and expose it to sunlight, develop it (KPR solution) and you see light frosting on the protected design.
Etch in acid of your choice. Ferric Chloride is what most people use to make etched printed circuits. I have used sulphuric and hydrochloric acid. BOTH are dangerous.
My Old buddy made silk screens for his tee shirt business using the same stuff.. you develop it and wash out the non-exposed photoresist. The ink.paint in the silk screen process does not go through the clogged up developed silk holes and only goes through the pattern of non-developed screen.. Pretty cool huh? same process.. different application.
By the way, he is gone for the second time counterfieting. He will never get out of prison again. DOn't do that. He had a iQ right on up there, but was too stupid to make his money legal like..
David Cofer, Of:
snowman
09-25-2004, 09:22 PM
I have been doing jewelry for a bit. Mostly fabricated sterling.
Take above method of cutting small slits into the stainless, then instead of using brass and gluing it in, simply braze some bronze into it. Then recut the ring. If you want something more fun, find a product like liver of sulfur that will patina the filler material, but not the stainless. Then you'll have a black lines. Oh, I dont think liver of sulphur works on bronze, can't remember for sure.
Simple brushed stainless is nice too...brushed stainless rings sell for about 50 bucks each in galleries. I would do more work in stainless if it wasn't such a pain in the butt to cut. Maybe it's just the alloy, but it kills the blades on my jewelers saw.
Etching copper is fun, but copper rings will turn your fingers black. I have no clue about etching stainless, but my guess is not with ferric chloride (radio shack circuit board etchant)...you'd probably have to use an acid of some sort.
-Jacob
Hot&CoaledForge
09-25-2004, 10:24 PM
Here's a recent etching thread regarding stainless:
http://www.knifenetwork.com/forum/showthread.php?t=24433
The gentleman does amazing work!
- Jim
Tony
09-26-2004, 04:04 AM
my Machinery's Handbook doesn't have a conversion chart for Ring Size -> Internal ID.
I live in europe so i'll need to find some ISO or DIN specs. http://bbs.homeshopmachinist.net//smile.gif
curious: how would one bond gold to stainless?
i've never been a fan of gold jewelery.. i have a braclet or chain i got once for a birthday.. i could hammer it down and use it to inlay a stainless ring. gold-leaf seems chintzy. how would i bond it? arc welder?
etching sounds interesting. though jewelery making is already unexplored territory for me, i'd hate to ruin a potential new hobby with acid burns on my eyes.
anyone have pictures of rings they've made?
how about that really complex stuff.. how do they do that on jewelery? are we talking smithing here, with really really small chisels? (before the advent of engraving)
i'd masacre anything with a dremel in my hand.
-tony
gunsmith
09-26-2004, 06:16 PM
Gold inlays are done by cutting a vee grove similar to a dovetail and gold being soft it is hammered into place in the groove. I've had rifles in my shop with this done on them. It can then be carved or in some cases stamped with patterns. The lost wax process is pretty much standard for gold jewelry. This can give you unlimited and complicated patterns. Give it a try, it is a great hobby. I paid for my first casting machine and oven by bulldozing a property for a friend who wanted to change his landscaping. Had to be 150 years ago now. Don't regret it because it fits right in with the gunsmithing.(casting new parts for old guns)
mochinist
09-26-2004, 08:08 PM
Here is a link to a ring size conversion calculator.
http://www.onlineconversion.com/ring_size.htm
snowman
09-26-2004, 08:14 PM
You can get ring sizers really cheap...and it's somewhat useful to have around. I bought my last set for a whopping buck.
If you are etching copper, the fumes aren't that bad. Any time you are using acid, you need to have good ventilation.
As far as putting patterns into sheet material, you can do it with a roller or a press. Make a positive of what you want out of wire, tape it to a piece of paper, tape the paper to the top of the sheet and run it through the roller (a small slip roll would work, anything that will develop enough pressure to push everything together). You'll get a nice imprint of whatever your wire design was.
check out www.bonnydoonengineering.com (http://www.bonnydoonengineering.com) they sell a basic jewelry press for volumetric stuff without spending hours with a hammer and anvil or mini punches and pitch (hard tar).
-Jacob
spope14
09-26-2004, 08:44 PM
I made a real nice ring out of 17-4 PH for a person once. made the ring itself on the lathe, and did some small longitudinal and lattitudinal line engraving using a dividing head.
made a second one a couple of years later - same bar of 17-4, only this time did some 30 degree each side of center 3-D engraving on the CNC machine using a 5-C collet index and tooling.
real ring making is a true art....I hope you get the info and such to do this to your satisfaction, and share your results an (hint) your methods so we can learn (borrow, copy) them from you.
PS - I use 17-4 because it does not turn fingers green, polishes up to a brilliant shine, an does not scratch easily. Stay aay from brass (green finger syndrome), or aluminum (black finger syndrome).
09-26-2004, 11:47 PM
One suggestion for a clearly non-wedding ring would be a layered ring.
You can do this several ways.
One is to lay up several rings of thinner material of contrasting material. Then you turn, file, whatever the ring shape, getting a "tire-tread" look.
If you do that but at an angle, you get interesting edges, which also can occur if you taper the ring as you would for a setting.
If you make the soldered-up assembly thicker than required, and bend it so its wavy before you turn it, you get a sort of wood-grain after it is in final form.
There are even more interesting things you can do along that idea, but they are difficult and not for the beginner.
Or, you can apply those ideas to a ring made up of slices going the other way, so that the ring has a pattern like a coral snake, with bands along the circumference.
Just a few ideas.
vinito
10-05-2004, 09:34 PM
time stamp bump
pgmrdan
10-07-2004, 08:24 AM
http://www.ganoksin.com/
http://www.ganoksin.com/borisat/nenam/mn-18k-yellow-gold-platinum.htm
[This message has been edited by pgmrdan (edited 10-07-2004).]
