View Full Version : Slightly OT: Carburetor Float question?
11-04-2004, 09:04 AM
Anybody know the float setting for a Marvel Schubler updraft?
I have been told parallel to the bowl deck with the flaot valve shut.Any clues?
Bill Cook
11-04-2004, 09:49 AM
Turn the carb up side down. Make it paralell with just the weight or the float resting on the valve. If it has a drop setting, adjust it so the float doesn't touch the bottom of the bowl (right side up).
Bill Cook
Joel
11-04-2004, 03:13 PM
When I can't find a recommended float setting, I also turn the carb upside down and set it parallel. This seems logical and has worked every time so far.
11-04-2004, 10:26 PM
Then parallel it is!Thanks!
Arcane
11-05-2004, 08:45 PM
http://www.juniorscomputer.com/massey/pg6.shtml has some specs as does http://members.aol.com/naa60512/carb.htm It seems to vary with model of carb.
