View Full Version : Somthing missing BP cnc collet
sdeering
11-18-2004, 09:45 PM
When I purchased my mill it came with two styles of collet holders
This collet works fine.
http://img.photobucket.com/albums/v510/sdeering/colletholderg.jpg
This collet when tightened still has space at the ends of the collet. Collet does not tighten up, any ideas.
http://img.photobucket.com/albums/v510/sdeering/colletholderng.jpg
Stephen
Also included with the collet parts are these whatchamacoletts aneyone know what they are for. They almost look like they would take up the space in the second collet set but they have an internal thread, a different size for each one.
http://img.photobucket.com/albums/v510/sdeering/unknownparts.jpg
Thanks for any info.
[This message has been edited by sdeering (edited 11-18-2004).]
suprdvn
11-19-2004, 01:29 PM
The first set is known as DA series (double angle). My DA180 (or 180DA) collets go up to 3/4". Yours may be the next larger series.
vmil3
11-19-2004, 11:39 PM
Your second Collet chuck is known as a Dead lock chuck. These chucks hold threaded end mills the different threaded plates fit the different dia. end mills. The plate and end mill are placed in the collet then sliped into the chuck then the chuck lock nut is threaded on the chuck by hand. The end mill is bottomed in the chuck by turning it in till the end mill bottoms out, now you tighten the lock nut.
Note these chucks are for threaded end mills only. One maker is Clarkson.
Doug
vmil3
11-19-2004, 11:59 PM
<font face="Verdana, Arial" size="2">Originally posted by vmil3:
Your second Collet chuck is known as a Dead lock chuck. These chucks hold threaded end mills in the different threaded plates which fit the different dia. end mills. The plate and end mill are placed in the collet then sliped into the chuck, then the chuck lock nut is threaded on the chuck by hand. The end mill is bottomed in the chuck by turning it in till the end mill bottoms out, now you tighten the lock nut.
</font>
sdeering
11-21-2004, 10:23 PM
Thanks Doug, now that you have mentioned it I do remenber seeing endmills with treded ends. All makes sense now.
