.........First what I'm doing is to have a 1/2" dia steel rod fit inside the bored plastic sleeve, which itself fit's inside a steel cylinder. The 1/2" rod will only make a low speed 90* rotation back and forth to open and close a passage.
I purchased a 1"x12" solid rod of each material. The plastic sleeve will be about 2 to 2.5" long. I need to bore and have an almost .0000" fit. Or more likely a slight interferance fit. I'm counting on the natural lubricity of the plastic to allow the smaller steel rod to rotate.
I'm thinking that the best way to bore the hole in the plastic would be to press it into the outer steel sleeve, chuck the assemby and then bore?
What kind of SFM should I use, and feed for boring this type plastic.
Thanks,
Rick
Thanks,
Rick
