View Full Version : Getting the bugs out...... and winning!!!!
G.A. Ewen
12-06-2004, 03:41 PM
Well after 8 months of near inactivity in the shop circumstances have changed for the best and I'm back at it. http://bbs.homeshopmachinist.net//smile.gif
When I last worked on my little lathe I was not getting a good finish on steel turnings. Brass and aluminium wasn't to bad but with steel chatter was a problem.
It seems that the problem was with the chuck. All I did was make a heavier backing plate for it and the chatter problem is gone. I guess that it needed a flywheel to smooth out the transmission of power from the motor.
This is a piece of hot rolled mild steel.....
http://img.photobucket.com/albums/0603/GAEWEN/Tools%20and%20Machinery/6e9994ec.jpg
Here is the old back plate...............
http://img.photobucket.com/albums/0603/GAEWEN/Tools%20and%20Machinery/c96b5d18.jpg
And here is the chuck mounted on the heavy back plate..............
http://img.photobucket.com/albums/0603/GAEWEN/Tools%20and%20Machinery/f5b47c0e.jpg
The next thing to do is to get the power feed up and running.
BillH
12-06-2004, 04:25 PM
I think I see a carbide toolbit in the toolpost, HSS would work better.
hoffman
12-06-2004, 04:27 PM
What kind of lathe is that?
Congrats on the progress!
[This message has been edited by hoffman (edited 12-06-2004).]
G.A. Ewen
12-06-2004, 04:38 PM
<font face="Verdana, Arial" size="2">Originally posted by hoffman:
</font>
Home built. (an ongoing project)
http://img.photobucket.com/albums/0603/GAEWEN/Tools%20and%20Machinery/177f2667.jpg
Bill, you are right, it does work better with HSS but I want it to work well with carbide to.
hoffman
12-06-2004, 05:02 PM
That is the coolest! Gotta ask; What's the coffee can on the back for? And what's "XRD"?
Hoffman in Warner Robins Ga
pgmrdan
12-06-2004, 07:19 PM
Good questions hoffman. And I gotta ask what are Always Thin Maxi's? The drawings make them look like peanuts. http://bbs.homeshopmachinist.net//biggrin.gif
"A woman on her period is like a tire fire. The more you try to put it out the worse it gets. It's best just to let it burn."
Hank Hill
[This message has been edited by pgmrdan (edited 12-06-2004).]
bernie
12-06-2004, 07:45 PM
Wow! That looks great George. Did you build the compound? Are we goimg to see the project in HSM? If so I think it'll be a great project.
Thanks for the update.
rotate
12-06-2004, 07:56 PM
Excellent work George. It looks like something out of Blade Runner.
Are those square tubes from stationary battery rack?
More pictures please http://bbs.homeshopmachinist.net//smile.gif
laddy
12-06-2004, 09:06 PM
Hey,
Fantastic looking lathe!! What a beautiful job. Awesome**
Fred
G.A. Ewen
12-06-2004, 10:00 PM
Thanks for the kind words.
The coffee can covers the open frame motor that I am going to use for the power feed.
XRD = eXe ReDesigned (look here.. http://www.lathes.co.uk/exe/page3.html )
The compound came from 'Smithy'. I intend to build one for this lathe once I have all the bugs out of it.
HSM artical? Possibly an artical showing how to build some of the components that would be usefull to others who would like to design and build thier own small lathe.
The square tubing is just 2-1/2" seamless hitch tubing.
My goal when I started this project was to build a good working lathe from readily available materials. So far, so good.
I think that I will give it a good test by building the "Buoy" engine from the latest Machinist's Workshop.
J. R. Williams
12-06-2004, 10:10 PM
Try sharpening the carbide tool bit with a good quality diamond grinding wheel to get a sharp edge with a slight radius on the tip for the finish cut. Your tool does not look very sharp.
JRW
