View Full Version : Forgive me Master Builder for I have sinned
.RC.
12-15-2004, 05:12 PM
Yes I admit it. I did it. I succombed to peer group pressure.
Where to start. hmmmm Well I so badly wanted to make round balls with my lathe. Balls so round and shiny that everyone would be impressed with my turning skills.
So I took a drill a drill so shiny and sharp that it was like nothing on this earth.
And that drill sung to me it sang how it wished to be plunged into metal and spun round and round until nothing but a magnificent round hole was formed.
I was mesmorised by this singing. It put me under it's spell. It made me do it.
So I grabbed my cross slide from the lathe and did so plunge the said drill into it and created a magnificent round hole a hole, so round and true it should not be of this world.
And then I plunged again and another hole was born.
Then a grabbed a 8mm tap and it also sung to me. It sang grand songs of how much wonder it could bring to me if only I would place it in the magnificent holes and rotate it.
So I placed the tap in the hole. And then rotated the said tap to create a wonderous thread. A thread so beautiful I believed the Master Builder would be pleased with my effort.
But then reality struck and the euphorism wore off. What had I done??? My God what had I done. Now my lathe. My beautiful lathe was unoriginal. It had been defaced by the two said holes in the cross slide.
I defiled the machine, the machine that another true believer in Taiwan had spent many countless hours building only for me to treat it like something lower than a snakes belly.
If only.......If only I had not read that thread about the ball turning tool...If only that drill had not sung to me...
If only I had bought a lathe with T Slots on the cross slide then I would not have had to drill those holes in the cross slide.
Please forgive me Master Builder......
[This message has been edited by Ringer (edited 12-15-2004).]
Tinker2
12-15-2004, 05:42 PM
Try a different coolant.
http://bbs.homeshopmachinist.net//tongue.gif
vinito
12-15-2004, 05:46 PM
My lathe likes chips in the pan - kinda like scratchin' an itch.
You know, a beautiful woman is a total waste unless she gets defiled now and then.
http://bbs.homeshopmachinist.net//biggrin.gif
hoffman
12-15-2004, 05:48 PM
Bet that cast iron drilled Gooooood! (Go on, do it again http://bbs.homeshopmachinist.net//smile.gif )
Hoffman in Warner Robins Ga
mayfieldtm
12-15-2004, 05:57 PM
Ya Know!
It's not a good idea to smoke funny weeds and run machinery. http://bbs.homeshopmachinist.net//biggrin.gif
Tom M.
12-15-2004, 06:13 PM
I'm sure glad my SB9 came with two 5/16 threaded holes already in the cross slide, from the factory. Whew. I sure wouldn't want to go through what Ringer did. No siree. Not ever.
mayfieldtm
12-15-2004, 06:52 PM
double post
[This message has been edited by mayfieldtm (edited 12-15-2004).]
BillH
12-15-2004, 07:01 PM
Im sure whoflungdung wont mind that you drilled some holes into his creation.
12-15-2004, 07:37 PM
Thats nothing,its a useful,neatly done mod.Me I have an old conehead lathe that was given to me,30x120",the guy beforeme needed a gap in the bed just ahead of the chuck,he did it with an arc gouging rod http://bbs.homeshopmachinist.net//eek.gifnow that is blasphemy!
.RC.
12-16-2004, 05:12 AM
No I wasn't on anything when I wrote that.. http://bbs.homeshopmachinist.net//biggrin.gif http://bbs.homeshopmachinist.net//biggrin.gif http://bbs.homeshopmachinist.net//biggrin.gif
I already had two holes on the cross slide that the taper turning attachment bolted to.
I put the other two near the top slide. I drilled and tapped them them so I can bolt on other attachments like the ball turning tool(when I make it).
John Stevenson
12-16-2004, 05:28 AM
<font face="Verdana, Arial" size="2">Originally posted by Ringer:
</font>
You can't use the term Master Builder and Taiwan in the same passage.
You have to accept these are kit machines and those two holes were probably missing because OneHungLow was behind on his daily quota of 2,487 machines.
Kevin F
12-16-2004, 06:52 AM
John, You crack me up! http://bbs.homeshopmachinist.net//biggrin.gif
The rest must have been good for you
Kevin
gkman11
12-16-2004, 07:15 AM
THANK YOU THANK YOU. Neither my ball turner (tested last night) or my mill attachment will work right because I,ve been unwilling to make the Rice Gods angry and swiss cheese my cross slide 'TIL NOW!
Swarf&Sparks
12-16-2004, 12:47 PM
Ah, grasshopper. Now you may form perfect spheres, through drill them and part them off. You must now part them into hemispheres, paint them white, and place them in your eye sockets. Then you too will be a master oriental machinist and look just like me, Kwai Chang Cain http://bbs.homeshopmachinist.net//biggrin.gif
chkz
12-16-2004, 09:46 PM
you been drinkin' the coolant Ringer??....lolol...great post! loved it...
chris
Thrud
12-17-2004, 04:40 AM
What John said... http://bbs.homeshopmachinist.net//biggrin.gif
shawnspeed
12-17-2004, 09:32 AM
Yes people do worse, my lathe was purchased at a severe discount because someone wanted a little more clearance under the chuck... got it with a torch, has not made the machine any less usable,just more ugly. I will repair it one day, already have the material on hand just need time, the RJ (real job) gets in the way like that all the time.
.RC.
12-18-2004, 01:46 AM
And here I was thinking you would be groping for my blood and expecting calls for my head to be cleft from my shoulder for having such gall to deface a lathe. http://bbs.homeshopmachinist.net//biggrin.gif http://bbs.homeshopmachinist.net//biggrin.gif http://bbs.homeshopmachinist.net//biggrin.gif http://bbs.homeshopmachinist.net//biggrin.gif Man that coolant tastes nice.LOL
Tuckerfan
12-18-2004, 08:38 PM
It could be worse, you could habitually leave the key in the chuck like my supervisor does. Or rig a cut-off on the machine with a C-clamp and a notched board, or order the wrong part to repair the lathe, and decide that instead of sending it back to get the right one, you'd "modify" it so that it would work, like he does. . .
