aboard_epsilon
01-09-2005, 06:58 PM
I'm making plain bearings
for the swing-arms of my boat trailer.
why stainless......because the thing will be submerged in salt water.
I've made the bearings .......out of 400 grade stainless..that's all I can tell you ......it's slightly magnetic and was the hardest thing I've ever drilled.
UNIDENTIFIED SCRAP YARD STUFF.
If titanium is magnetic then it could well be titananium ..I struggled with cobalt drills.
Now the pins that go into these bearings I've not made yet....they will be 1 inch diameter
1.do I make them out of stainless as well
2. do you think I should make them out of a softer metal....there would be less strengh then..(trailer will carry about 1.5 tons.
I ask because ..there must be something in this softer metal against harder metal as bearings because they've been doing it for years in car engines.
or does this not count here because bearings pins will only be turning thru 20 degrees...and want be doing it very fast.
bear in mind that I dont have much money to go out and buy some smart stainless roller bearings
All the best..mark
All the best..mark
