View Full Version : Proper oil for my lathe
cuemaker
01-14-2005, 12:51 AM
1969 Clausing Colchester.
Manual says for the head stock, Shell Tellus oil 27 and for the gear box Shell Tellus oil 33 and same for the saddle and slide one shot.
Follow the manual for 1969 or earlier or are there better choices these days?
Thanks
3 Phase Lightbulb
01-14-2005, 12:58 AM
Vactra 4 in the carrage, Vactra 2 on the ways, DTE 24 (ISO32) in the gear box.
Here are some pictures of my bottles of oil at the bottom:
Click for pictures of the bottles (http://www.gnuxtools.com/garage/DSCN3952.JPG)
-3Ph
[This message has been edited by 3 Phase Lightbulb (edited 01-14-2005).]
cuemaker
01-14-2005, 01:02 AM
I knew I could count on you!
Thank you
BillH
01-14-2005, 01:03 AM
I like your setup and organization.
Also like the big pictures, but again im not on dialup.
cuemaker
Ooops, you said carriage, does that mean headstock????
3 Phase Lightbulb
01-14-2005, 01:05 AM
Sorry, you want to use Mobil DTE Heavy Medium circulating oil ISO 68 in the head stock... Don't use the light oil there.. I use it for my hydrolic variable speed, but that's different.
-3Ph
3 Phase Lightbulb
01-14-2005, 01:07 AM
<font face="Verdana, Arial" size="2">Originally posted by cuemaker:
Ooops, you said carriage, does that mean headstock????</font>
The apron sump in the carriage. Fill it with Vactra #4 -- you should have a little window somewhere (It might be painted over so scratch around if you can't find it)
-3Ph
cuemaker
01-14-2005, 01:08 AM
Ok, then what oil for the gears in the head stock?
cuemaker
01-14-2005, 01:09 AM
forget it, didnt read up far enough, sorry
Thank you for the help, again.
3 Phase Lightbulb
01-14-2005, 01:14 AM
Just to recap:
Headstock - Mobil DTE Heavy Medium circulating oil ISO 68
Ways - Mobil Vactra #2
Apron sump - Mobil Vactra #4 (or ISO 220 gear oil)
Screws and general bearings - Mobil Vactra #2
-3Ph
3 Phase Lightbulb
01-14-2005, 01:17 AM
Do you also have the variable drive with hydrolic system?
-3Ph
cuemaker
01-14-2005, 01:22 AM
Umm, I dont think so.
cuemaker
01-14-2005, 01:24 AM
also, the ways are also done on the one shot pump. which one should i choose?
3 Phase Lightbulb
01-14-2005, 01:27 AM
also, the ways are also done on the one shot pump. which one should i choose?</font>
Use Vactra #2 in the one shot pump. Or, remove the one shot pump and give it to me because my Clausing doesn't have one. http://bbs.homeshopmachinist.net//smile.gif
-3Ph
3 Phase Lightbulb
01-14-2005, 01:35 AM
<font face="Verdana, Arial" size="2">Originally posted by BillH:
Also like the big pictures, but again im not on dialup.</font>
I have my bridgeport in the corner, and I built those two angled benches for easy access to tooling on both sides:
My Bridgeport Mill (http://www.gnuxtools.com/garage/DSCN3954.JPG)
-3Ph
matador
01-15-2005, 12:22 AM
3ph,you don't have enough collets to fill your rack.better go out and buy some more! http://bbs.homeshopmachinist.net//biggrin.gif http://bbs.homeshopmachinist.net//biggrin.gif.
Hans
