The magnetic chuck on my surface has reached a point where it should be ground. I have done it once which turned out to be quite a process. Would appreciate information on the proper way of doing this. Type of wheel to use, grit size, and a general procedure. I'll heed your advice. TIA
StephenK
StephenK
