www.glacern.com
Go Back   The Home Shop Machinist & Machinist's Workshop BBS > Third Hand
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 10-19-2009, 10:03 AM
Bourne Bill Bourne Bill is offline
Junior Member
Default jet 1024, or 1236 owners
can anyone tell me where the drainplug for the headstock is on either of these lathes? Thanks in advance Bill
  #2
Old 11-02-2009, 11:55 PM
KiddZimaHater KiddZimaHater is offline
Sorry Bill, I have the Jet 1236, and still haven't found a drain plug.
  #3
Old 11-03-2009, 07:03 PM
dkhntr04 dkhntr04 is offline
Junior Member
I have a 1024. Not sure exactly what you are asking. I have not found a drain plug for the power feed gearbox that is located on the headstock. The oil from lubricating the pulley bushings and gears inside the actual headstock drips down and drains through a hole in the headstock casting through the headstock side leg.
  #4
Old 11-04-2009, 11:06 PM
Junior Member
Default jet 1024
im looking for the drainplug for the main shaft bearings in the headstock. Im assuming they are in an oilbath, because of the oil level windows.
  #5
Old 11-05-2009, 06:40 PM
Timo Timo is offline
Member
I have a 83’ vintage Jet 12 x 24, with the sight glass’s and there are no drain plugs.
  #6
Old 11-10-2009, 10:31 AM
techonehundred techonehundred is offline
Junior Member
To drain the oil in these lathes, you just have to remove the plastic level gauges. They are just held in by an O-Ring.
  #7
Old 11-11-2009, 12:27 AM
Junior Member
Thanks for that Tech.........
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
