Reply
  #1
Old 01-14-2006, 06:43 PM
Mcgyver Mcgyver is offline
Post grinding fixture build - VERY long w/pics
I wanted a universal fixture for the T&C grinder, capable of holding drill bits and lathe tool bits so that I could easily to facetted drill sharpening, acme or V thread bits etc. I had fun taking pics through the build and thought you guys might enjoy them
The assembly was fabricated using my stick welder
Here’s an overview of the unit after welding
I sent everything out to be normalized and had the drill V-block case hardened at the same time. Well worth the $30 to know its going to be reasonably stable
For accurate work, you need a reference surface. I decided to scrap in one side of the elbows so there would be no distortion from clamping. Started with the power scraper
and finished with a hand scraper. Almost complete blue-out – good enough for the girls I know!
I bolted each elbow to a tool makers block (made by yours truly, hardened and ground square to 1/10 thou all over and done as a matched pair).
The elbows are now all squared up.
  #2
I then made an arbor for the lathe to clean up the circumference.
Here’s an elbow, square and ready for divisions
I graduated each axis in degrees – TEDIUM! Gotta get the 4 axis cnc built!
With one disk graduated, the other needs a witness mark. Here I’m using an indicator to get the disk’s face parallel to the machine’s axis before make a witness mark on the base
Graduating all done!
Here’s progress to date, I mainly included this shot to show the tool bit holder attachment.
Now things get messy. I used auto body filler, spot putty and a couple of coats of cellulose primer with sanding in between
[This message has been edited by Mcgyver (edited 01-14-2006).]
  #3
Old 01-14-2006, 06:44 PM
This is chronologically a bit out of order – machining on the V-block was done prior to case hardening. Here am drilling the two longitudinal holes, one for the tooth rest gizmo and the other for rest at the end of the drill. The two bars the make up these mechanisms are held via cotters – you can see the brass cotter the intersects the hole and the ¼ ready rod holding it in place
Here the V is being cut.
Here’s the drill stop – am adjustable gizmo that the end of the drill rests against. There are a couple of different attachments for this – ie a long thin adjusting screw for very small dia drills and different lengths of the long rod. It will hold drills from 1/16 to 1” or more
I made this ‘third hand’ rig and posted pics of it here awhile ago, and a few wanted to see it in use – here you go. It’s a real time saver, otherwise to do this job properly you’d be pinning or such the pieces together. The work piece is the
I get the best silver solder results by placing small pieces of solder in the flux and then just warming everything up
Here’s the tooth rest body after pickling and slitting
The tooth rest is almost done. There will be a micrometer feed on the end, I still have to make the screw and end piece. The idea is that between its built in adjustments and the convenience of the cotter holding it in the V block, its quickly adjustable to any position and then the micrometer adjustment can bring the tooth rest do the final position
  #4
The V block is being set up for grinding. It was ground all over after case hardening and an oil quench.
Here’s the completed unit. I used the Tremclad hammer finish paint – I don’t think I’d recommend it and probably won’t use it again but don’t have energy right now to refinish.
I hope this helps or interest you guys.
  #5
Old 01-14-2006, 06:50 PM
BillH BillH is offline
wholy cow, that came out great
  #6
Old 01-14-2006, 06:52 PM
japcas japcas is offline
Mcgyver, that is some nice looking work. It looks like a casting that has been smoothed after all of the filling and paint work you did, really makes the job look professional. Also the graduations look great and should prove real useful.
__________________
Jonathan P.
  #7
Old 01-14-2006, 07:04 PM
mochinist mochinist is offline
Damn fine job Mcgyver
__________________
FuQ
  #8
Old 01-14-2006, 07:11 PM
Forrest Addy Forrest Addy is offline
OK you newer guys.
Here is a crystal clear example of how a project goes from need to concept through the stages of manufacture to a handsome finished and practical end product that fulfills the need.
You who are new to the home machine shop should print out this thread and file it in your library under "inspiration."
McGyver, you're all but a few thousand words of narrative short of an excellent and informative article for HSM or MHSW. I suggest you stress the needs from which the concept sprang and be sure to include some words about how you made your decisions about size and feature. Add a few of your preliminary sketches and why they failed to make the cut.
[This message has been edited by Forrest Addy (edited 01-14-2006).]
  #9
Old 01-14-2006, 07:16 PM
billyboy billyboy is offline
Send a message via MSN to billyboy Send a message via Yahoo to billyboy
well done!, its a lovelly piece of workmanship, this is exacly what this forum is for, i think you have inspiered me to look at this build nearer summer for my tool and cutter grinder, i dont think that ill bother with the filler as i like to see the swirly cutter marks on the finished piece, or is there something wrong with me? but a lovelly finish to the job. 10 outa 10.
bill
  #10
Old 01-14-2006, 07:17 PM
aboard_epsilon aboard_epsilon is offline
Mcgyver.
Your machine work is exceptional.
Welding ...Ummmm...I'm going to be honest...you need more practise ....but in all honesty.........it doesn't matter ..because the results at the end are a masterpiece.
I would like to see more of how you put the numbers and graduations on ...as I've never done this before and it would be of interest to me.
Also the way you have posted this step by step.. is the way to go .more people here should be doing this ....pictures speak a thousand words........and you don't need many words to describe what is going on.
You do it so well.
Cant wait for the next post when you make other things for your cutter grinder .marvellous
all the best.mark
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
