Reply
  #1
Old 02-05-2006, 03:13 PM
Mcgyver Mcgyver is offline
Post Tool grinding jig PT II (lots of pics)
For those of you not sick of my grinding pics, here’s a follow up and some shots of it in use
First off, I redesigned the micrometer tooth rest – it needed more of an offset and longer range. Here it is ready to go – 5 separate silver solder joints on this assembly
The V block is case hardened and ground all over, also finished the cotters so both the drill stop and tooth rest is very easy to adjust.
The angles are set on the graduated dials on the universal swivel, I was doing a 118 point with two clearance facets, one at 15 and one at 30 degrees. The drill is placed in the v block and the stop and tooth rest adjusted then tightened down. I generally index the drill and do both cuts on one facet then change the angle of the base to do the second facet or bevel. Over the past couple of week ends I made a mobile stand for bench top T&C – I found it really hard to set up (ie tooth rest) if I couldn't get access all around the machine to view the set up.
Grinding grinding grinding
By making different lengths of rod for the drill stop, the rig can hand almost any size drill
The final result. Yeah, I can sharpen a drill by hand but it will take me a lifetime of Sundays to get so that they are as nice as this. Since they are virtually perfectly symmetrical, the cut very accurately. The one I tried and measured was within a thou, give the limits of small hole gauges.
[This message has been edited by Mcgyver (edited 02-05-2006).]
  #2
Old 02-05-2006, 03:19 PM
mochinist mochinist is offline
As usual mcgyver, nice work.
__________________
FuQ
  #3
Old 02-05-2006, 03:22 PM
Dawai Dawai is offline
Yeah I laughed about the "bondo" on the tools.
I am impressed by the end results.
Tools should not be so fancy you have to wax them. Looks good thou.
I plan on copying it.. somewhat.. My own way.
__________________
Drove the old El Camino to the rubbish dump today, the 400hp engine sure made it fun.. When I passed the kid in the rice rocket car he had a funny look on his face, the tires were still smoking. (who's the old grampa in the wailing elky?) NOT that I'd promote street racing or anything illegal..
  #4
Old 02-05-2006, 04:13 PM
japcas japcas is offline
Mcgyver, the only reason we would be sick of seeing this thing is because we don't have one for ourselves. That is nice looking work and a very useful tool. I think it is great to be able to freehand grind tools, but it is hard to beat a good machine grind and the consistency of the grind. Do us all a favor hear and make up some prints, I would definetly buy a set from you and I am sure others would too. Better yet, do up an article and send it in to the magazine.
__________________
Jonathan P.
  #5
Old 02-05-2006, 04:25 PM
TECHSHOP TECHSHOP is offline
Smile
Mcgyver:
PLEASE PLEASE PLEASE stop posting pictures on here!!
You're making me feel TOTALLY inadequate - not to mention dirt-poor.
Every time I see pictures of your projects I try to plan ways to rob the local Wells Fargo Depot!
Today I will gladly share my experience and advice, for there no sweeter words than "I told you so."
__________________
  #6
Old 02-05-2006, 04:33 PM
IOWOLF IOWOLF is offline
Wonderful work,just wonderful.
The tame Wolf !
  #7
Old 02-05-2006, 04:53 PM
Your Old Dog Your Old Dog is offline
Thanks for posting. It's rather inspirational for us rookies. It must be nice to drill a hole and have both sides of the bit cutting equal amounts of metal. I wonder how you get it that good by hand or do you just put up with half the bit cutting and the other being ground just out of reach of the stock?
I fooled around in the shop today and had something to post but I'll wait a day or so till your's blows over That is unless someone else blows in here with their new homemade snowblower or something like that.
__________________
  #8
Old 02-06-2006, 12:02 AM
canman canman is offline
Member
Cool
Great job! The pics are great also.... How fast is your rig? Given a couple dozen of different size drills how much trouble(time) would it take to sharpen? Not rying to be a smart a$$ just considering if it would be worth the time and effort to add fixture to "list of items I deffinately need to make". Are you using a t@c grinder or a surface grinder with a cup wheel or what? Keep them project pics coming as they inspirational. A picture is worth a 1000 words and takes a whole lot less explaining.
Thanks
__________________
Kevin Middleton
Rome Georgia
  #9
Old 02-06-2006, 04:43 PM
thanks again for the encouraging words!
with the rig set up, ie bolted on the table, its a couple or maybe 5 minutes per drill, most of the time spent waiting for the wheel to spin down so you can get in and index the drill. Then again i've sharpened all of three drill this way so i'll get faster with practice.
i will do plans, in fact they are mostly done. don't think i'd sell though, it's a different dynamic selling instead of sharing. you're welcome to them when done.
oh yeah, its on a small T&C, but would work equally well on a surface grinder with a cup wheel.
[This message has been edited by Mcgyver (edited 02-06-2006).]
  #10
Old 02-06-2006, 11:38 PM
Member
Cool
It would be great if you could send me a copy of the plans, I have a B&S #5 surface grinder that could use a little work out...
Thanks,
Kevin
__________________
Kevin Middleton
Rome Georgia
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
