Quote:
Originally Posted by David E Cofer
http://bbssystem.com/viewtopic.php?t=1364
try that link for a pdf download. I gathered the pictures together real quic like last night and took them into a pdf format.
I keep things better tlike that.. if you save html, it may lose the picture links.
Nice roller by the way, a different style than Georges.. George's roller can replace a lot of tube benders.
figured this could be a new thread, thanks for posting that David. when i saw it reminded of a similair tool i built a while ago, a tubing straightener.
mine was made primarily to convert coils of copper tubing into straight lengths of copper tubing. the similarity of the two made me think a builder might incorporate both functions in a machine, although mine is for light duty stuff. the other trick for straightening copper tube is tie one end of against a tree and the other to a trailer hitch and give it s slight stretch. tried this once, just by pushing the car, works ok, might end up with a slightly smaller OD though
i disagree with it replacing a bender though, in my limited experience the rollers are used in increments, tough to do when you want a 90 degree bend. then again that's speculation, i haven't tried it.
