Reply
  #1
Old 02-15-2007, 05:20 PM
Rusty Marlin Rusty Marlin is offline
Default scissors knurling tool print HERE
Some of this is duplicated in my post on how to post pdf files, I aplologize for the rehash.
I needed a knurling tool and so I drew up the plans and it is this weekends project. In my searches for plans I noticed several requests, but none to be found. In the spirit of the this site's freedom with information and projects, I want to share my plans with all of you here on HSM. So here they are; Evan is graciously hosting the plans as a printable pdf file. Scissors Knurl
http://i61.photobucket.com/albums/h4...NURLARMASM.jpg
Please note: the axel drawings numbers are for holding the center of the scissors at the centerline of my 13" Grizzley in a 4way tool post. Other than the axel the drawings should be universal.
As YOD has pointed out, they are also available in this month's ENCO Hot Deals cat. for 28 bucks... But where's the fun in that?
__________________
  #2
Old 02-15-2007, 05:25 PM
Your Old Dog Your Old Dog is offline
Quote:
Originally Posted by Rusty Marlin
As YOD has pointed out, they are also available inthis months ENCO hot deals cat. for 28 bucks... But wheres the fun in that?
As I bang this responce into the computer Athur Mometer says it's 12 freaking degrees out there. In here is where the fun is !!
BTW.....Nice job on the project and the drawing
  #3
Old 02-15-2007, 05:59 PM
7018 7018 is offline
I have 3 or 4 plans for the scissor knurling,But these seem to be the best so far.Thanks for posting them...
  #4
Old 02-15-2007, 06:07 PM
mochinist mochinist is offline
I bought one of those for work about two weeks ago and let me tell you, I feel like a fool for using the old style knurl for all these years.
Thanks for the plans, when the shop is slow, I will have the guys make some up for each lathe.
__________________
FuQ
  #5
Old 02-15-2007, 07:13 PM
Evan Evan is offline
If anybody else has plans for similar small projects they would like to share I will be happy to host them on my site in the same manner as Rusty's. I will be putting that knurler on my ever growing list of things to do.
__________________
Project gallery and Machining/Electronics Reference Library: Ixian.ca/gallery
The universe doesn't care whether you know how it works.
Post may be edited for spelling or typos.
  #6
Old 02-15-2007, 10:05 PM
BadDog BadDog is offline
One suggestion, add a hairpin spring to that design to hold them open against the nut. I have a smaller Boyar Shultz sissor knurler that is made on a different principle, and I generally like it better, but the main point is that it has a spring to hold it open and BOY does that make it more convenient.
  #7
Old 02-16-2007, 09:02 AM
deere_x475guy deere_x475guy is online now
The spring is definately a good idea. I built mine a little different. Mine will self align to the centerline of the part and I am not sure that this one will.
__________________
Bob
Pics of shop and some projects
http://s2.photobucket.com/albums/y39...achine%20Shop/
  #8
Old 02-17-2007, 05:52 AM
Buckshot Buckshot is offline
..........Great set of plans. I bought a scissors type from ENCO. Not the Eagle Rock at $128 but the cheap ones. It works but is sloppy and the knurls do not track in line. The 2 arms are pivoted on a shouldered bolt and the fit is rather casual. The top knurl is about a 32nd behind the bottom knurl. BTW, the knurls supplied with it are crap. Plus the knurl axles are merely pressed into the arms making it a PITA to change wheels.
I substituted 1/4" drill blanks for the axles, then ground a slot in the side of each to accept a steel shim in the form of an arm that is attached via a button head hexscrew.. This locks the axle in place, yet swing it up out of the slot allows the axle to be simply pushed out for wheel changing.
Rick
__________________
Son of the silver stream ..... Bullet caster.
  #9
Old 02-17-2007, 07:27 AM
Popular plans Rusty, getting close to 400 page views.
__________________
  #10
Old 02-24-2007, 07:04 AM
I had a couple folks e-mail me about the mod to the scissors knurl, so I'm posting a photo:
On the left side of the arms you can see the additions. I should have put them on the right side. I pressed out the issue axles, reamed the holes and as mentioned above, used .250" drill blank material for the new axles. With a slot ground in each end, the steel sheet metal 'keeper' sits in the slot and keeps the axles from working out.
Loosen the buttonhead setscrew and push the keepers out of the slot and then you can push the axles out to change knurl wheels. Since some of the knurl wheels I have are 1/4" wide I made spacers. Merely drilled and reamed some 1/2" drill rod with a 1/4" hole and then parted them off like fat washers.
Rick
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
