Reply
  #1
Old 04-02-2007, 03:46 PM
opua opua is offline
Member
Default digital bevel
The latest electronic aid to the workshop is worth a second look. This little cube can be magnetically attached to any steel or magnetic surface and set to zero, any movable part can then be set accurately [reportedy within 0.1 degree] RELATIVE to that surface.
example, I needed to set my shaper head to 2.5 degrees, set the cube on top of the head and puish zero, tap the head to the setting required and tighten the bolts checking that the readout didn't change, all done in seconds!
this is the link http://wixey.com/anglegauge/index.html [usual disclaimers]
Paul Z
  #2
Old 04-02-2007, 03:54 PM
Forrest Addy Forrest Addy is offline
Now THAT's something to look into
  #3
Old 04-02-2007, 04:13 PM
miker miker is offline
Thumbs up
Thanks for posting Paul. I would like to see one of those.
Rgds
__________________
Michael
Australia
  #4
Old 04-02-2007, 04:28 PM
The Doctor The Doctor is offline
Seems like a very good way to spend $40, I'll let you know how it works when it arrives From the FAQ:
How does it read? All of our readouts use what's called capacitive measuring technology. This is the exact same system that is used in almost all digital calipers that have been on the market for at least 20 years. There is a circuit board on a rotating counterweight that has a repeating pattern etched on it. There is a second fixed circuit board with a similar pattern and the rest of the electronics. As the 2 patterns pass over each other there is an electronic signal generated that is converted to rotation angle. The only moving part is the circuit board with counterweight passing over the fixed circuit board. There is no electrical connection between the 2 circuits boards and they do not even touch each other. There are no other mechanical moving parts.
They also carry a 6" digital caliper with a 64ths fraction readout, as well as a planer readout and fence readout for woodworking with those same features.
Ed
  #5
Old 04-02-2007, 04:29 PM
cmiller231 cmiller231 is offline
No address , No phone , no country.Makes me wonder . The owner says he is too busy ,deals through internet only..Probably not much to worry about ,it is sold through Woodcraft Supply also.Could use one now myself.
Chris
  #6
Old 04-02-2007, 05:17 PM
John Stevenson John Stevenson is offline
Do a google plenty of people selling this.
http://www.hartvilletool.com/product/12456
Hang on a bit though as some of the prototype Chinese mills are having these fitted to the tilt heads as standard.
__________________
Sir John, Earl of Bridgeport & Sudspumpwater. MBE
[ Motor Bike Engineer ] Nottingham England.
  #7
Old 04-02-2007, 05:47 PM
lazlo lazlo is online now
Quote:
Funny -- that's a compact version of the digital protractor for sale at MSC, J&L, Enco, etc:
http://cgi.ebay.com/ws/eBayISAPI.dll...m=160102101367
Same resolution (0.1 degree) too.
Great price as well!
  #8
Old 04-02-2007, 07:00 PM
japcas japcas is offline
I got mine from a local Woodcraft store and it has been real handy around the shop. Also useful for setting the occasional piece in the vice at an angle for those odd jobs.
__________________
Jonathan P.
  #9
Old 04-02-2007, 09:51 PM
The web page lists no address, but I got this from my paypal transaction page:
Ship From:
Barry Wixey Development
5306 Umbrella Pool Road
Sanibel, FL 33957
United States
They are also a paypal verified member, which means something, I guess.
Ed
  #10
Old 04-02-2007, 10:35 PM
BobWarfield BobWarfield is offline
I had coveted the more expensive brethren of these little guys but hadn't wanted to pay the price. I bought the little guy as soon as it came on sale. It went on a shelf like most things to wait until I needed it.
After reading this thread I pulled it off the shelf to try a few tests with it. Apparently my granite surface plate is level:
And my 30 degree angle block is really 30 degrees:
Unfortunately my lathe is not so level (DOH!):
Ya'll did see that 0.050" gage block peeking out didn't you? It woulda been hidden under my Starrett level:
Anyway, I have deemed it a swell gadget worth the having.
Best,
BW
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
