Reply
  #1
Old 05-05-2007, 05:54 PM
Mcgyver Mcgyver is offline
Default A tube bender saga
I made this a few years, ago but used it today and have never taken photos of it so thought you guys might like to see it.
occasionally when making models, one has to bend copper tubing. the typical tube bender, while successful in creating a bend, is not up to the task for modeling as 1) it won't work to a small enough radius and/or 2) distorts the shape of tubing around the curve - ie not a smooth transition from curve to straight on both the inside and outside curves. Thus began a bunch of experiments and reading on to produce a decent bend in a tube.
What I came up with has two unique (well they were to me anyway) features. 1) the outside die, rather than being a round die like the inner is straight. 2) the outside, straight, die, gets tightly pressed against the inner die, sandwiching the copper tube between them. This done via an eccentric axle. If you look in the pic, you’ll see the straight die, then a cylindrical spacer. It's this cylindrical spacer that is on an eccentric shaft.
Here a bend is being set up. The tube clamp shows a larger allen key setting the orientation of the clamp along a tee slot, while the smaller one clamps the tube itself. I made slit spacers for different sized tubing. In the main pivt, about the round die, there are spacers such that it is firmly bolted to the base, yet free rotate.
here's a shot after completing the first and second bends. the tube was annealed for these bends
  #2
Old 05-05-2007, 05:55 PM
(stupid image limitation)
here's a close up showing the fairly decent shape that is maintained. ideally the bend looks like 1/4 of a torus without kinks or ploughed-up leading edge to the bend.
of course, if you're going to make a tube bender, you're going to do so for all sizes of tubes and radii. Should I ever commit a heinous crime, I consider this important work towards my insanity defense. It handles tubing from 1/8 to 3/8 by 16th’s
after cutting to length and some emery and polish work, here's the finished product. It’s sitting on the block to which it will one day be attached. Imo it turned our well, its a .5" centre radius bend in a 5/16 tubing. Still, the Stuart plans (this is for a triple expansion) calls for a 5/16 centre line bend, the accomplishment of which still eludes me, even with this rig. perhaps filling with cerro or something.
  #3
Old 05-05-2007, 06:11 PM
knucklehead knucklehead is offline
holy smokes, mcgyver, thats some pro looking work there.. good job.
some of those surfaces look hardened?
-tony
  #4
Old 05-05-2007, 06:43 PM
Ken_Shea Ken_Shea is online now
That is a very neat set up McGyver, nice job.
Looks very complete
  #5
Old 05-05-2007, 06:58 PM
Carld Carld is offline
Very nice set of benders. Someone in the future is going to think they have a factory made set.
__________________
  #6
Old 05-05-2007, 09:20 PM
Rich Carlstedt Rich Carlstedt is offline
Very Nice WOrk !
They have the straight sections in "Large" Commercial benders
They are called "Shoes"
A shop my company had doing work for us used them when bending
our pipes. They could bend a 3 1/4" Stainless Pipe with a 7/8" bore and get a 6 inch radius ( or 7 5/8" C/L) for us.
Obviousely when you do something like that, You have to pay the vendor for making the custom shoes and rollers.
Rich
  #7
Old 05-05-2007, 10:06 PM
h12721 h12721 is offline
Member
Mcgyver,
(this is for a triple expansion) calls for a 5/16 centre line bend, )
Check your print, it is 4 5/16 CRS.
Hilmar
  #8
Old 05-05-2007, 11:21 PM
dp dp is offline
Lots of eye-pleasing workmanship detail work there. Very nice and just a little bit, no, a lot old school. Well done.
__________________
Dennis
  #9
Old 05-06-2007, 03:24 AM
Buckshot Buckshot is offline
........That is fabulous work. It shows a lot of attention to detail and the final finish is just great. Looks just like the kind of old time craftsmanship that's very hard to find these days. Except by dedicated individuals :-)
Rick
__________________
Son of the silver stream ..... Bullet caster.
  #10
Old 05-06-2007, 03:42 AM
Evan Evan is offline
Excellent job. I'll be posting pics of my sort-of-like-a-Hossfeld bender I recently built when I make a few more dies and have some work from it to show.
__________________
Project gallery and Machining/Electronics Reference Library: Ixian.ca/gallery
The universe doesn't care whether you know how it works.
Post may be edited for spelling or typos.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
