Reply
  #1
Old 08-06-2007, 04:13 PM
mklotz mklotz is offline
Default Sine bar protractor
Reading a conventional protractor to any decent accuracy always tries my patience. So, I built a sine bar protractor. As can be seen, in addition to the measuring arms, it has two rolls, similar to those on a sine bar.
An offset half-lap hinge allows both arms to close flat against each other.
In use the device is set (or read) with calipers reading the separation between the two rolls.
The mathematics for converting between angle and caliper reading are a bit complicated, so I wrote a program to do the dirty work. It's available in the PROTRAC.ZIP archive on my page.
__________________
Regards, Marv
  #2
Old 08-06-2007, 04:24 PM
Carld Carld is offline
Very nice. Yep, it would be difficult to compute since a sine bar is set using the verticle height and your bar uses a variable angle and gap to compute the correct angle.
I don't use a sine bar much but it is troublesome sometimes. I can see where you could stick that in an angle gap and set it to the angle there and then measure the gap between the pins and compute the angle. That tool has posibilities.
__________________
  #3
Old 08-06-2007, 05:26 PM
toastydeath toastydeath is offline
You've actually created a device a good deal more accurate than a sine bar (if it was made to the right degree of precision). Sine bars rapidly become sensitive to small changes in height the greater the angle, and rapidly lose accuracy. The thing you've got, sometimes called a microsine bar/table, eliminates the fundamental geometry problems encountered with a sine table.
The difficulty in calculating the angle is paid off manyfold in the accuracy of the angle it can be set to.
  #4
Old 08-06-2007, 05:49 PM
BadDog BadDog is offline
Yeah, errors can be rather large for large angles (generally over 45*). And not to split hairs, but technically not a "sine" bar anyway...
Nice as always!
  #5
Old 08-06-2007, 06:27 PM
Hmm..
How isn't it a sine bar?
http://en.wikipedia.org/wiki/Law_of_sines
  #6
Old 08-06-2007, 08:32 PM
The term "sine" bar has to do with the trigonometric function whereby you can determine the angle based on the height of the blocks where the orientation forms a right triangle. In standard form:
Quote:
sine(a) = opposite / hypotenuse.
But this is true only of a right triangle. When using sine bar, you know the hypotenuse, that's the length of the sine bar. You know the angle you want. So you solve for "opposite" and have your gage block stack.
The key measurement (the calipers) for the described device does not utilize the "sine" function because the orientation does not form a right triangle. Instead, it requires a more complex calculation represented by Marv's program he mentioned. It's generally simplified by expressing as 2 equal right triangles, so perhaps this would be a "double sine of half the angle bar"?
  #7
Old 08-06-2007, 08:51 PM
Tim Clarke Tim Clarke is offline
I like it. You guys who have served your apprentieships, or are knowledeble in math can juge the merit much better than I. However it looks like it's so simple that I wonder why I never thought of it. Seems like setting it with a height guage would be the way to go.
TC
  #8
Old 08-06-2007, 09:05 PM
I guess what I was saying is that sin(a) = o/h isn't the law of sines, from which I assumed sine tables took their name.
But I'm not into the history of the device so much, so I'm certainly not an authority on the taxonomy of it.
  #9
Old 08-06-2007, 09:13 PM
Oh, I'm certainly not either. I just always "assumed" (heh) that it was called a "sine bar" because of the simple basic trig function/equation employed in it's use. You can surely get there from the law of sines, but I never considered that the name was derived from the law of sines. <shrug> But as I said initially, it's "splitting hairs" anyway as we all know what he meant...
Edit
Tim: Setting with a height gage is possible, and takes you back to simple right triangle trig, but you loose your reference point, which complicates things again.
Also just noticed that the bottom pin is not located on line with the pivot, so it's more complicated than 2sin(a/2), or "twice the sine of half the angle".
  #10
Old 08-06-2007, 09:23 PM
dp dp is offline
Quote:
Originally Posted by toastydeath
Hmm..
A sine bar (as I understand them) requires that one angle must always be 90 degrees. This tool has no imposed angle of 90 degrees. A ray between the pin centers forms a chord of a circle with a radius of the pin/hinge length, and where the hinge is the center, but because the pins are not infinitely small in diameter the math to determine the angle is more complex as Marv has stated.
If you measure the distance between the points opposite on the pins, you actually describe a ray that extends symmetrically beyond the circumference of a circle by one half pin diameter, and which forms a chord of a circle between the intercept points of the circumference and the pin center. Measuring the adjacent points of the pins as shown in the photos describes a ray that is shorter than the chord of the circle by the diameter of one pin.
__________________
Dennis
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
