Reply
  #1
Old 01-05-2008, 06:08 AM
Evan Evan is offline
Default Engraving tool
I have been practicing my engraving skills the last few days and have managed to make the same mistakes only once each time, so far. The machine works great which is more than can be said for the operator.
This machine has a bit more grunt than the average engraver such as the ancient first generation New Hermes CNC engraver I used to repair for a local Jeweler. One way this can be used to advantage is to do "scratch engraving" in which the tool is simply dragged along the metal. Done right this displaces the metal neatly instead of cutting it and doesn't use the spindle motor at all, it is turned off. Your average dedicated engraver machine such as the old New Hermes isn't up to that as it requires several pounds of downforce on the tool.
It also requires very even pressure on the tool to produce a good result. One way to achieve this is to use a spring loaded tool. This also eliminates completely problems caused by slight warps in the metal being engraved and greatly simplifies clamping.
Yesterday I made a spring loaded engraving tool and did some testing with it. It is really nice and a lot less fussy to set up. It does a great job on aluminum, brass and silver. The tip is high quality carbide salvaged from a broken 1/16" solid carbide end mill that I had lying around.
The tool fits in a 5/8ths R-8 collet. It has an integral 1/8th inch collet chuck for the tips. Travel is about 1/4" with midrange exerting about three to five pounds of force. The tip of the tool has about a .010" radius.
The results speak for themselves.
That's my daughter. She is the best photographer I know. She just bought her third Canon XTI as a backup-backup camera. You can see her work at crazywolf.com
__________________
Project gallery and Machining/Electronics Reference Library: Ixian.ca/gallery
The universe doesn't care whether you know how it works.
Post may be edited for spelling or typos.
  #2
Old 01-05-2008, 06:15 AM
John Stevenson John Stevenson is offline
That is impressive, what did you do the text in ?
__________________
Sir John, Earl of Bridgeport & Sudspumpwater. MBE
[ Motor Bike Engineer ] Nottingham England.
  #3
Old 01-05-2008, 06:28 AM
The font is Caslon Openface BT. It's pretty close to a traditional engraving font.
__________________
  #4
Old 01-05-2008, 06:43 AM
Your Old Dog Your Old Dog is offline
That's pretty slick. Is it more of a burnishing affect or is it actually cut in? If there's a flat side to the bit it isn't showing to me. I can see this CNC mill opening up all kinds of worlds to you.
__________________
  #5
Old 01-05-2008, 06:55 AM
No flat side. The tip is a smoothly rounded profile. I haven't tried to measure how deep the grooves are but they are deep enough you can't buff them out with a buffing wheel. The tool doesn't cut at all. It also produces a very smooth and shiny surface as if flows the metal out of the way. If you do the math a few pounds on the tool turns into thousands of psi on the tip.
After I built the tool I decided to look one up on the net. I was surprised to find nearly the exact same thing from a company. Then I saw the prices, . $300 to $500 for nothing different from what I made in a few hours yesterday. I think I got a good deal.
__________________
  #6
Old 01-05-2008, 07:35 AM
Evan,
No not the text, what program did you do the text in to get the code ?
Yes those spring loaded tools are expensive.
I note they also list patent numbers for the tool and the add on tip.
However they got those I'll never know as they have been available in the UK for years.
The tip is standard fitting on Gravograph machines.
I made one a while ago out of one of these.
They are an ER11 collet chuck with a 16mm ground OD and a JT1 taper in the end.
Although they are hardened it's possible to cut a slot in the side for a peg to fit and allow it to slide in a holder. My holder is a blank R8.
These can hold collets from virtually zero to just over 1/4"
They are very cost effective and you can even use them as sub tooling similar to the Tormach quick change so you can keep the tool offsets. They cost about £15 each here.
I use mine for small hole drilling and engraving but unlike Evan I have never tried drag engraving.
__________________
  #7
Old 01-05-2008, 08:44 AM
Ah. I used CamBam to do it. It's rather awkward as it is not a completed product yet but it also does many things the way I like. It does have some problems that I haven't pinned down yet. For some reason it won't render certain characters in some fonts even though the font works fine in other programs. Also, CamBam doesn't do the best job of picking a tool path.
Something else that I am about to try is engraving a bitmap. That is usually done by varying the cutting depth in accordance with the light to dark values of the pixels. With this tool it should be possible to vary the pressure using the exact same code but the result will be a varying line width, the same as happens in certain half tone processes.
__________________
  #8
Old 01-05-2008, 08:48 AM
lazlo lazlo is online now
Nice job Evan!
Was that how John engraved the picture of the Sieg owner (varying the cutting depth according to the greyscale value)?
  #9
Old 01-05-2008, 09:13 AM
Evan, two things, first is Andy is about to launch a pro version of Cambam that may clear up a few items.
Second is if you want to do a bit map have a look at PhotoVcarve.
http://www.vectric.com/WebSite/Vectr.../pvc_index.htm
The download whilst being a demo does allow you to save and cut the examples supplied.
Failing that if you try your own file it will process it but not code it - demo limitation, but if you send me the file or pic I'll run it thru a full version and send you the code back.
__________________
  #10
Old 01-05-2008, 09:30 AM
BobWarfield BobWarfield is offline
Evan, that's cool!
This is the kind of thing that made me suggest to the fellow wanting to build scientific instruments that he needed an engraver.
A favor please: could you shoot a piccy that shows the components of your drag engraver laid out when it is disassembled?
Cheers!
BW
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
