Reply
  #1
Old 02-05-2008, 09:18 PM
garyphansen garyphansen is offline
Default Treepanning bit photo PLEASE
Could some one post a photo of what a treepanning bit should look like? I need to cut a 6" diameter hole in a steel plate in a lathe and I rather not drill and then bore it to size. Gary P. Hansen
  #2
Old 02-05-2008, 09:25 PM
aostling aostling is online now
Looks sort of like the lower jaw of a spawning salmon. http://www.jtsmach.com/jtswebshop/Pr...Tools/D327.asp
__________________
Allan
  #3
Old 02-05-2008, 09:26 PM
Carld Carld is offline
Well, there are a lot ways to make a trepanning tool. The cutter will be ground much like a grooving tool. That is it has a taper look to the top of it and the side clearance has to clear the diameter your cutting and it has to be able to clear the thickness of the work plus some. Do a google for beam hole cutter or trepanning tool and see what comes up.
Alan has it right since he is going to use a lathe. I edited my post to eliminate my incorrect reply.
__________________
  #4
Old 02-05-2008, 10:28 PM
tattoomike68 tattoomike68 is offline
This tool is a face grooving tool for a diameter range but thats the geometry in an exaggerated form.
same idea..
  #5
Old 02-06-2008, 10:05 AM
Allen: ,Your link does not work for me. Gary P. Hansen
  #6
Old 02-06-2008, 11:27 AM
I looked up trepanning on google but mainly all I found was a bunch of information about people drilling holes in their heads. Sounds like good fun doesn't it! Gary P. Hansen
  #7
Old 02-06-2008, 12:23 PM
Jim Caudill Jim Caudill is online now
Here are some trepanning tools. The one on the left is a metod of trepanning in a mill or drill press. The other 3 are HSS bit, similar bit in a holder, and an inserted carbide bit holder. Hope this clears things up for you.
  #8
Old 02-06-2008, 01:26 PM
ptjw7uk ptjw7uk is offline
Talking
Trepanning in the head - a bit difficult to get the head in the lathe!!
LOL
Peter
__________________
  #9
Old 02-06-2008, 03:33 PM
" a bit difficult to get the head in the lathe!!"
Naw, just cut the head off, people who would drill a hole in their own head were not using their head anyway. Gary P. Hansen
  #10
Old 03-22-2008, 04:45 PM
snowman snowman is offline
Hey Jim...
Did you make the trepanning tool for the drill press that is shown? How well does it work?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
