Reply
  #1
Old 07-19-2009, 09:42 PM
tmc_31 tmc_31 is offline
Default Autocad for the Mac?
Hello all,
Well I have dunnit, I've gone over to the dark side. I bought a Macbook Pro today. I am wondering (you mac users you) if anyone can recommend a CAD program (like AutoCad) that will run under Mac Os. It should read and write dwg. and dxf. files.
PS
I am going to try open office for a while to see if I like it before I lay down $ for Microsoft Office for the Mac. If any of you have any experience with this software, I would appreciate your insights.
Tim
  #2
Old 07-19-2009, 09:57 PM
MTNGUN MTNGUN is offline
Definitely give Open Office a fair try. It lags a few years behind MS Office in the whistles and bells department, but it does what I need it to do.
Dunno about CAD for Mac, but take a look at this discussion:
http://forums.macrumors.com/showthread.php?t=518459
Looks like they recommend either HighDesign or running ACAD in Parallels.
Can't blame you for ditching Billware. Wish there were more CAD/CAM options available for Mac and Linux.
  #3
Old 07-19-2009, 10:22 PM
lakeside53 lakeside53 is offline
Autocad on the mac? easy - just run the Windows emulator.
  #4
Old 07-19-2009, 10:31 PM
dp dp is offline
http://community.irhino3d.com/
You can also get Fusion from VMWare or Parallels from Parallels (both cost about the same), or VirtualBox from Sun Microsystems (free) and run Windows on the Mac in a virtual machine. They all have problems with 3D support in the video.
Finally, there's BootCamp, free from Apple, that lets you mult-boot to Windows or OS X (but not both at the same time as the above products do). This is the fastest method and has the best video support for Windows because everything is native. Windows doesn't care that it is running on Apple hardware.
Personally I'd rather pi$$ on a spark plug than multi-boot ever again so I don't use it. I use and recommend Fusion.
__________________
Dennis
  #5
Old 07-19-2009, 11:07 PM
rklopp rklopp is offline
I run SolidWorks 2009 under Parallels on a MacBook Pro running Leopard (OSX 10.5.7). It works OK, but the graphics are flaky. For example, pieces of parts and the text of dialog boxes disappears when you mouse over them. I am due for a Parallels upgrade, but don't know whether this will fix the graphics issues. I've heard SolidWorks runs fine under BootCamp. Fortunately, I don't make my daily living running SolidWorks this way, I just do it in a pinch when on the road. Also, the company pays for the software.
I have a buddy who works for the Evil Empire, who runs Windows Vista on a MacBook Pro. He says it's one of the best Windows machines there is. He particularly likes the glass "zero-button" mouse.
  #6
Old 07-19-2009, 11:13 PM
MickeyD MickeyD is offline
If you are not doing anything too complicated Viacad works well. Not the most powerful program in the world, but it has some nice 2d and even 3d tools that get you up to speed quickly. I have been using it as my main drawing program for over 2 years now and I am pretty picky on software. They have both a Mac and Windows version so you do not have to run it under a win vm (and suffer the shorter battery life). http://www.punchcad.com/products/viacad2d3d.htm
  #7
Old 07-19-2009, 11:22 PM
Pherdie Pherdie is offline
I have both Parallels and Fusion (on two different, his and hers, Mac/Intel machines). I highly prefer Fusion. Much more seamless, free updates and seemingly more preferred by most.
That being said, I ran into major vector video problems attempting to run an R/C flight simulator in a Fusion supported Windows Vista image. If I use Bootcamp and boot directly into Vista, the simulator software runs great, but I lose the ability to jump at will between OS's. The video issue is not unique to the software I was attempting to use. VMWare says it Apple's fault (insert finger pointing here).
Bottom line, if your going to run specialized graphic intensive Windows software on a Mac, check to see how other Mac users have fared first!
  #8
Old 07-20-2009, 01:45 AM
gearedloco gearedloco is offline
Talking TurboCAD Mac
Quote:
Originally Posted by tmc_31
Hello all,
PS
Tim
Some might say you departed the Dark Side and entered the True Light.
I bought TurboCAD Mac Delux for around $100. It's the first _real_ CAD program I've tried to use. Assorted extensions are available for 3D modeling, etc.
I also got the tutorial, which is some help. What I really need to to is to take a few days and really work with it. I really have to beat on something like this to retain any skill.
The vendor I used is <https://www.shopimsi.com/>. Hope this helps!
-bill
  #9
Old 07-20-2009, 05:24 AM
Bmyers Bmyers is offline
try NeoOffice, it is open office for MAC OS X.
I use Qcad, it only supports .dxf but was only $39.00
  #10
Old 07-20-2009, 07:13 AM
airsmith282 airsmith282 is offline
Send a message via MSN to airsmith282
being i have been an apple/machintosh user sence 1982 and an apple tech sence 1990 i have a p and c list ill share iam also a pc tech and pc user as wel sence 1997
mac first
1 con expensive to buy
2 con expensive to fix when hardware goes wronge
3 con lags bad in game play and lack of games access
4 con lags in surfing
5 con pain in the ass to make music and dvd cd's
6 con imac line of macs is a total waste of money andis alot like MS the line is junk .desktops always rule complacted trash cans converted to fish tanks later where the big down fall even though the were popular they broke alot, no a wise but to get and all in one machine ...
7 con the mac onterface or OS as its called was one of the best untill the adaptation of OSX and the UNIX core, the mac was a virus free inviroment until OSX came out and the unix core is worse then DOS ever was,working under system 9 and lower was a pleasure and if something went wronge it was so easy to fix and fast to fix now its like PC when crap happens it can be hell and usually is even settting up mac network now is difficult compared to before when it was like plug click connect and do your thing..
ok the nice list for mac
1 pro for doing photo shop and music and animation/movies you cant beat a mac doing music recording totaly awesome as well...
2 pro prices have come down a bit but no near enough yet.
3 pro the most mac systems last for ever it seems other then the imac line of macs
4 pro apple/ macintosh family line of computers sence the start have always been able to run dos/windows after alll apple invented widows to start with, under emulation its a bit boggy but not to bad to deal with pcs however can now run os X so its equal playing field now,
5 pro macs have a cool look right off the hop thats appealing.
6 pro macs are one of the more like the easiest to use of all computer platforms out there userfriendly 100%
7 pro even though macs can now get virused its extreamly rare compared to windows PC's which get nailed alot if your not carefull
8 pro printing quaility using the same program same exact printer and so on the mac will still blow the doors off any pc using the same,harware and software, anyone that says different needs to repent now and ask the computer gods forgivness..
ok time to bash the PC a bit
1 con widdows is not an Its a commanline interface that hovers over DOS even thought vista and windows seven are catching up to macs their still not there yet..
2 con virus's happen alot on PCs its more cridicul to run a pc on the net for example then a mac
3 con pcs can not output the same graphic quaility as a mac
4 con hardware quaility on pcs is not near as good as a mac but they are cheaper to fix
5 con pcs are frustrating when trying to set up a net work letaone an internet connection at times, somestimes the harware you want wont work on just any pc some or so specific its crazy not user friendly at all
6 con easy to crash a pc and lose all your junk really fast not very good there at all..
7 con you cant just take your windows os and put a copy on your buddies machine for him other wise you can lose your windows licence access, you cant even do it on your own home systems unless you buy a muilty user licenes and even then if someone cracks it and uses it you lose again,..on a mac i can use one cd on a billion macs and apple dont care..
ok nice time for the PCs
1 pro surfs faster then a mac
2 both are equle using adobe adution infact i like the PC version better
3 pro pcs now use quicktime and itunes not a bad idea there however i perfer widnows media player my self
photoshop on screen they are the same just not on paper mac is still better.
4 pro when it comes to games the choices are endless and they run fast as hell i love it..
5 pro office and open office are the same on both mac and pc
6 pro pcs can run OSX
7 pro program access is higher on pcs then on macs
8 pro cheap to buy cheap to fix but life span is shorter on a pc compared to a mac,, pcs like to be kept cold macs love to run hot
9 pro graphic quaility on games for pc rule and more game varity on pc then on mac
10 pro pcs are taking on some style these days macs still all look the same in most cases..
11 pro accessories and toys for a pc are very comman to find but not so much for the mac
so a basic hit list on both sides of darkness and the light, i was once a total mac head and my wife hated me for it, but now iam a PC freak and she loves me more but in the end i still perfer my pc over the mac. for my uses and my budget the pc fits right in to my life perfectly..
at times i miss having a mac but on the other side apple/macs are going backware in quaility now to much and performance for home users they are comming fastly to and end and they are still to dam expensive to buy and to fix and so on and so on...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
