Go Back   The Home Shop Machinist & Machinist's Workshop BBS > Gunsmithing
Reply
  #11
Old 08-27-2009, 07:59 PM
loose nut loose nut is offline
Vol 2 see if you can download from here
http://fliiby.com/file/34280/qg8np4slqm.html
  #12
Old 08-27-2009, 08:02 PM
You can also get them from here plus loads of others
http://www.stevespages.com/page7d.htm
The barrels and actions book would have to be bought but only if you can't get what you want from the others.
  #13
Old 08-27-2009, 10:04 PM
pinkmoose pinkmoose is offline
Junior Member
Default Brownell's
My old man before he died built one of barrel drills that brownell's sales the video/dvd for. It worked quite well, we did several 20 cal barrels. Building one is quite a project, I think he did it so he could say he built everything on the gun; barrel, action, and stock.
  #14
Old 08-28-2009, 10:43 AM
NickH NickH is offline
Thanks for those excellent links loose nut, interesting readin there,
Regards,
Nick
  #15
Old 09-04-2009, 08:14 PM
wierdscience wierdscience is offline
Quote:
Originally Posted by loose nut
Download "The Modern Gunsmith" (1941) by Howe, it can be found on the web, for free. It will tell you everything there is to know about making barrels, the necessary equipment and how to make it, tooling, jig and fixtures etc.
"Barrels and Actions" (1991) by Harold Hoffman can be purchased on the web, fairly cheap too, and while it isn't as good it has a lot of good info including that on button rifling and how to make a button rifling machine.
Making barrel rifling machines and equipment isn't very hard, using that equipment to get a good barrel is the tricky bit. Don't expect success right out of the gate.
Just downloaded The Modern Gunsmith,all I can say is WOW!That is about as thorough as it gets,worth the time just for e section on engraving and checkering,Thanks for the link!
__________________
Prepare for the unknown by studying how others in the past have coped with the unforeseeable and the unpredictable.
George S. Patton
  #16
Old 09-04-2009, 08:30 PM
JCHannum JCHannum is offline
I have a hard copy and will not part with it. It is one of the classic gunsmithing books. James Howe is the Howe of Griffith and Howe, makers of some of the finest custom rifles ever made.
__________________
  #17
Old 09-06-2009, 11:46 AM
Another good book, not as good as the modern gunsmith but a good read and a free download is "Advanced Gunsmithing", link below
http://www.scribd.com/doc/8697640/Advanced-Gunsmithing-
  #18
Old 09-18-2009, 03:19 PM
cuslog cuslog is offline
Member
This guy has a good setup. I made a copy of it, made a couple pistol barrels.
First one was a total failure, second one worked OK though.
Fairly big learning curve (for me at least) but I did learn quite a bit and it is neat to be able to say that "yes, I did the rifling too".
http://www.homegunsmith.com/cgi-bin/...+bo ot+pistol
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
