#1
I have a BP S2 CNC machine I have had up and running for almost 2 years now w/ leadshine drives and Mach 3/ PC controls.
When I bought the machine it came with a 14" (IIRC) rotary table also stepper driven. The controls were originally setup to unplug the Y axis and plug in the rotary axis and still have only three axis control. I will still need a fourth drive, but other than that, I have everything to put the rotary axis back in place. From the research I am doing, I know that the CAM software has to support rotary machining, and that most packages in reach of the average hobbiest only allow for 3 axis at one time. I don't really have anything specific in mind for the rotary table, but I would like to get it up and running over the winter. I am thinking mostly I will be using it for cylindrical milling, but I have it in the back of my head that it might be nice to be able to use it for machining multiple faces and entry points into a part. It seems to me that the latter would require all four axis to be usable at the same time. So, my questions are, is Mach3 capable of running more than three axis simultaneously? Their software description says it can run 6, it has been a long time since I read the manual, but I was thinking it was still limited to only running three axis at one time... Then, my next question, is what am I looking at in CAM packages? I have played with the Vcarve demo, and Artcam Pro, both of which I believe will do cylindrical milling with a fixed Y, what would I need to get into to allow full 4 axis control? Any explanations or pointers on more reading material would be great. I am not finding much info in my online searches, and CNCzone keeps locking up my browser on my work PC here... Thanks, Jason |
#2
Quote:
Yes. Quote:
Have a look at Dolphin Partmaster. That supports 4th axis. Quote:
If you think a little about what you are doing, you can generally get away without true 4-axis unless you are doing something really complex. For cylindrical milling, where you might only be moving X- and A- together, a bit of Excel, enhanced by HuntnPeckCAM works well. For multiple faces, use your standard CAM package for each face and then FingerCAM to link them together and change offsets as necessary. |
#3
Mach will do 6 axis at one time.
The cam is where its going to get you. 3 Axis is pretty reasonable in price, add a 4th axis and the price goes up big time. On my machine I just figure the item as flat and replace Y with A and go for it. But that has its limits. 14" rotary table. That a lot of weight for that table. |
#4
Thanks guys, that is kind of what I figured I was going to hear. I am not sure that I will ever use the 4th for anything but artsy stuff. I have a friend who wants a ring and I have some ideas for cylindrical engravings. Most likely A,X,Z will be fine, but it seems if I am going to go to the expense of another drive I ought to investigate all the options. If I stick with 3, I can just go with a quick connect on the Y like B'port did from the factory and save $130 on the 4th drive.
Any suggestions on more advanced CAM packages that do full 4 axis? Do any of them have trials or demos that can be DL'ed and tried to get the feel and see if I like it? Quote:
The table was a factory add on to the series 2. I have the serial numbered manuals that show it came with the machine. The S2 is probably 1.5x-2x's beefier than a series one in the base casting. I am sure I'll have to re-tune the axis to account for the weight, but I don't think it will be to much for the machine. Thanks! Jason |
#5
No free software that I know of, not even cheap ones.
#6
Yeah, not looking for free or cheap, just a demo, even one that doesn't produce code, just to see how easy it is to learn.
Ill keep searching, thanks! Jason |
#7
Interesting piece of software mark, just downloaded it for a further look. Thanks.
| Display Modes | |
