Reply
  #1
Old 12-08-2009, 07:30 PM
wierdscience wierdscience is offline
Default What I did today (pics)
Being soaking wet outside I decided to do one PITA shop repair/mod and one Backburner customer part.
The first is a flyweight for the brake on a casket lowering hoist.Extreme right is the damaged old weight,center the one good weight that was left and on the left we have a plaster mould of the good one.
The nould was just a section of tubing tacked to a plate with an old roller chain leaf for a support to hang the good weight from while the plaster dried.I sped up the drying process with a couple hours in the heat treat furnace set on 250F.
Once the plaster was set,a couple good taps with a screwdriver handle and the original popped out leaving a good cavity for the new pour.Clamped in the old weight stem,re-melted the old weight along with an old battery terminal and poured.The new weight shrank predictably and popped right out.Some cleanup with a file and all is well.
__________________
Prepare for the unknown by studying how others in the past have coped with the unforeseeable and the unpredictable.
George S. Patton
  #2
Old 12-08-2009, 07:33 PM
lazlo lazlo is online now
Nice job Darrin.
__________________
He who loves practice without theory is like the sailor who boards ship without a rudder and compass and never knows where he may cast.
  #3
Old 12-08-2009, 07:35 PM
Second is the PITA fix I have been planning,but didn't have time for.
2hp Taiwan B-port clone,as typical no good surface to pull on when sliding the motor forward or back to change speeds.Capacitor can was always handy,but always working loose as a result.
So I rolled up a ring from 1 x 3/16" flat stock,welded on a couple chain links for a hinge and added a handle and two bosses for the drawbolt.
Here it is installed,makes life easier already.
__________________
George S. Patton
  #4
Old 12-08-2009, 07:45 PM
Frank Ford Frank Ford is offline
Cool, I'll remember that chain link hinge. . .
__________________
Frank Ford
HomeShopTech
  #5
Old 12-08-2009, 07:48 PM
lugnut lugnut is offline
Thumbs up
What Frank said, I really like that chain link thing
Mel
  #6
Old 12-08-2009, 09:29 PM
Tony Ennis Tony Ennis is offline
Chain link hinge is genius.
I like the lead mold, too.
  #7
Old 12-08-2009, 09:48 PM
Fasttrack Fasttrack is offline
Send a message via AIM to Fasttrack
+4 on the hinge ... I've got about 8' of 40 (or was it 60?) chain from a combine that I couldn't let myself throw away, despite being junk. Now I've got a use for it ... a whole bunch of hinges ...
  #8
Old 12-08-2009, 09:54 PM
Doozer Doozer is offline
Drop Dead Gorgeous!
--Doozer
  #9
Old 12-09-2009, 06:08 AM
gda gda is offline
Another vote for the coolness of the chain link hinge!
  #10
Old 12-09-2009, 07:59 AM
Thanks guys,guess you can tell I didn't grow up in the city
Heck I should probably do a post on just all the incarnations of roller chain hinges
__________________
George S. Patton
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
