Reply
  #1
Old 01-03-2010, 07:54 AM
Jerry Jerry is offline
Member
Default Drill-Press - Improved
This modification that I made to my drill press table, has proven to be very beneficial. I think that my drill-press is probably typical of most of the drill presses out there with a crank-up table. I always disliked the way the table had to be raised and lowered, all the while keeping a eye on the work on the table or in the vise, as well as the tool mounted in the chuck. I was in a surplus center one day when I spotted this gear-head motor assembly. Looking at the specs, I noticed the 25 RPM rating, and doing some calculations in my head, I decided to purchase it and take it home. It was a simple modification to add the spacers and mounting-plate you see in the photo. The motor is 110 volt and reverseable. I wired the toggle-switch shown, into the electrics of the drill-press. A adapter was made up, that couples the output-shaft of the gear-head assembly, to the input-shaft (where the crank attached on the drill-press) of the table assembly. After some layout work on the side of the table-casting, 2 holes were drilled and tapped that matched the mounting plate, to mount this assembly on to the side of the table casting. The holes were simple to drill with a hand-drill. Upon using my new attachment for the first time, I never looked back, and I am not sure if the crank even exist in my shop any-longer. Now I can run the table up and down, from the front of the drill-press without any effort, and the gearing has proven to be right on the mark, as the table raises and lowers at a good rate of speed, yet very controllable when the work is approaching the tool mounted in the chuck.
Jerry
  #2
Old 01-03-2010, 08:10 AM
Carld Carld is offline
Hmm, nice idea and I will have to watch for a gear reduction like that I could use on mine.
__________________
  #3
Old 01-03-2010, 08:22 AM
928gene928 928gene928 is offline
Member
Default Drill Press
Jerry,
Great idea, and you sure did a nice job on the modification. I currently use a long stroke hydraulic jack to raise and lower my table. You have a much better method, and is easier than messing around with a jack. I will see if I can do something similar. Thanks for sharing!
  #4
Old 01-03-2010, 08:25 AM
Member
My photo gives you the idea that the assembly is larger than it actually is. In reality it is quite compact and tucks in close to the drill-press. When swinging the table from side to side, this assembly follows nicely.
  #5
Old 01-03-2010, 08:27 AM
airsmith282 airsmith282 is offline
Send a message via MSN to airsmith282
nice job man very well done saves on the arm mussles to
  #6
Old 01-03-2010, 08:29 AM
motorworks motorworks is offline
Jerry
Nice idea
Now that is what I need on me BP mill
__________________
please visit my webpage:
http://motorworks88.webs.com/
  #7
Old 01-03-2010, 08:32 AM
Duffy Duffy is offline
That is a VERY elegant solution to the problem.
I took a more "Heath Robinson" approach. I picked a cheap 3/8" drive socket that just slid over the crank shaft, and drilled and tapped it for a set screw. I use a stubby rachet handle for most of my adjustments, since they usually only require drill length changes. For serious winding, a cordless drill is usually handy nearby. I think I made the modification about fifteen years ago, but it really hardly rated a mention. It was just THERE! Duffy
  #8
Member
Quote:
Originally Posted by motorworks
Jerry
Nice idea
I'll post photos in the near future of a power-feed that I added to my Emco FB-2 Mill soon.
  #9
Old 01-03-2010, 11:36 AM
dockrat dockrat is offline
Jerry
Nice idea
GMTA!!! the first thing I thought of when I saw that was it would be perfect for raising and lowering the head of my RF45 mill. Great idea Jerry and neatly put together. Where did you find that unit??
__________________
Ernie (VE7ERN)
  #10
Old 01-03-2010, 11:38 AM
nheng nheng is offline
Very nice job and inspiration to do something with my BPT knee. Den
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
