#1
Just in case there is some of you that do not have this addition added to your drill-press, I suggest that you spend a couple of hours in the shop brewing up this most handy of accessories for your drill-press. Once in place, you will wonder how you did without this drill-press tray. I initially built the tray without sides, and in short order added the rim to keep the various drill-bits and what not from falling on the floor. If I was to build my drill-press tray over again, I would make the arm a little longer, to position the tray further out from the drill-press. Still, I am more than happy with my drill-press tray, after using it for a number of years.
__________________
http://www.jerryclement.ca/ |
#2
Nice idea and well done.
__________________
It's only ink and paper |
#3
I like it, makes more sense than using the table of the bandsaw sitting next to the drill like I do. Interesting, I use the same two cutting fluids.
me |
#4
Hi how is the coller support fitted to the drill column?Alistair
__________________
Please excuse my typing as I have a form of parkinsons disease |
#5
By the look of things, the hard (heavy) way, of removing the drill press head and slideing it onto the collumn
#6
That is correct, I removed the head and positioned the collar in place on the column. It was simple to do, as the drill-press head was not all that heavy. Actually, another way of making the collar, would be to turn the collar to size in your lathe, and then weld or silver-solder lugs spaced 180 degrees apart on the collar (drill and bolt the lugs together for alignment, before welding them in place on the collar) and then split the collar in half between the lugs. At that point it would be as simple as placing the collar around the drill-press column and with the correct spacers in place between the lugs, this would allow for free movement of the collar on the column.
__________________
http://www.jerryclement.ca/ Last edited by Jerry : 02-19-2010 at 02:00 PM. |
#7
I asked a truck shop to save me an old crankshaft connecting rod to do the same thing.Had to shim the big end with a piece of belting.
#8
Nice addition! That DP looks like my 12 speed HF that I bought back in the early 80's. It has been a great machine and is still going strong. I will have to make one of these trays to "buy me some bench space."
Thanks for the idea,
__________________
Jim (KB4IVH) Only fools abuse their tools. |
#9
Quote:
__________________
http://www.jerryclement.ca/ Last edited by Jerry : 02-20-2010 at 03:11 PM. |
#10
Jerry...Wow! That is some neat power table lift! The head looks identical but my DP is a table model. It has the same tilt mechanism and table. The knobs were the only cheap out on the one I got. You know, the knobs were just a bolt with a plastic head cast on it. They work but make it look like a real cheap setup. The machine cost me $169 delivered and I could not even buy a sheet metal special at Sears for twice that but the cast iron was really good and the machining was top notch. The quality varried on those machines from brand to brand so I guess we got lucky.
__________________
| Display Modes | |
