Reply
  #1
Old 03-07-2010, 10:16 AM
DICKEYBIRD DICKEYBIRD is online now
Default Lathe spindle speed "locked" to work diameter.
My mind is wandering this morning as I'm turning out a batch of small parts. I know, dangerous but sometimes that's when my brain spits out ideas.
As I was cranking the handle, watching the chip curling off during the gazillionth facing cut I thought "Man I wish I had a CNC lathe with spindle speed/diameter compensation" or whatever it's called when the spindle automatically speeds up to keep the SFM constant.
Then I thought if I had a variable speed setup on my lathe spindle, (treadmill motor/controller or whatever) how hard would it be to rig an encoder to the crosslide or from a DRO output into the motor controller to make an automatic speed increase as it travels across. Seems like that should be a fixed relationship and fairly easy for you guys that understand electrons and magic smoke. What say ye expurts?
Since they're ain't nuthin' new in this world, it's probably been done before, yes?
__________________
  #2
Old 03-07-2010, 10:19 AM
lakeside53 lakeside53 is offline
Yes.. it's been done. You can buy a module for two of the high end DRO's (Newall C80 and some of the Accurite/Anilam models). If you're interested in the issues it's worth downloading the manuals for those modules.
http://www.acu-rite.com/CMSFiles/Fil...nual_Oct09.pdf
http://www.newall.com/PDFs/downloads...p8css-user.pdf
I just turn my VFD speed control as I'm cross feeding (for now)
  #3
Old 03-07-2010, 10:32 AM
Asquith Asquith is online now
This is how Cunliffe & Croom did it in 1914.
  #4
Old 03-07-2010, 10:36 AM
Peter. Peter. is offline
I have a variable-speed lathe so I knock the lever up a notch at a time as I face the ends of stuff.
__________________
  #5
Old 03-07-2010, 10:40 AM
Quote:
Awesome pic, thanks! I wonder how the variable speed was accomplished?
__________________
  #6
Old 03-07-2010, 11:00 AM
Hal Hal is offline
Monarch offered that on some of their machines and call it CSCS. Constant Surface Cutting Speed.
Hal
  #7
Old 03-07-2010, 11:03 AM
Dickeybird,
DC motor, variable resistor, chain connected to the cross slide!
  #8
Old 03-07-2010, 12:35 PM
macona macona is offline
It was an option on the monarchs as well. One of those things I would like to add to my 10ee. Make sure you have something that sets max permissible speed as well.
  #9
Old 03-07-2010, 12:56 PM
Now THERE'S a technology I can understand!
__________________
  #10
Old 03-07-2010, 01:51 PM
philbur philbur is offline
There are lots of machines out there with constant cutting speed. For example.
http://www.knuth.de/produkt,2032.html
Seems to me it's almost a natural consequence of having a DRO and VFD fitted.
Phil
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
