Results 1 to 10 of 13
Thread: OT: What adhesive for this application?
    Nov 2005
    You might want to look at a product called loctite 3030. This should give a decent bond between the hdpe and steel according to the datasheet (or at least in shear--typical of most adhesives). In my testing of bonds between ldpe and hdpe/uhmw/pex with this product, the plastic substrate generally fails before the glue joint providing the joint is designed semi-correctly.
    If you go this route, you will need an applicator gun and the correct mixing nozzles(10:1). Your local supplier might not think that this is the case...trust me it is..insist on it.
    BTW, I don't have any connection with loctite but this product has saved the day on a few projects for me.
    Best of luck.
    Mitchell
    Mar 2004
    Western WA
    Post OT: What adhesive for this application?
    I need to glue some thin strips of hdpe (plastic) strips onto 5/8" square steel tube. I can either glue it on prior to paint (if that's better from an adhesion point) or after paint.
    What adhesive would work for this application?
    Thanks
    Wayne
    I think the concensus is that there's NO adhesive that will really bond to HDPE. Some epoxy resins will form a "mechanical" bond if the surfaces are roughened, but it's not going to last past a little flexing or expansion and contraction of dissimilar materials. Your best bet is to use mechanical fasteners.
    Roger
    Apr 2005
    Polyurethane cement is about the only thing I know of that will work.
    52N 122W Western Kanuckistan
    Loctite "Glue for all Plastics" should work. It glues teflon just fine.
    Nov 2005
    Mount Clemens, Mi
    This site might have some ideas its glue all the time. but the other post are right I really can't add much other than screw thru the tube in to the plastic if you can would be the best bet. next would be a rail welded to the tube on each side of the strip and grooves in the strip's edges and then stops on each end.
    http://www.thistothat.com/
    Probbally would help if I put the site link in here. must be to much glue sniff with them AMT kits from the 60's LOL
    Glen
    Been there, probally broke it doing that
    [This message has been edited by PTSideshow (edited 02-27-2006).]
    Glen
    Thanks Glen, you just gave me an idea for an unrelated project I'm working on.
    Nov 2004
    GunGrabbin' Republik o' Kalifornia USA
    Hot Glue. If you can, heat the metal part to make it warm, then apply the hot glue to the metal, and affix the plastic. I would test a piece first to make sure the heat from the melted glue does not distort the plastic strips.
    Duke Reno / Yankee Metallic Metalcraft
    Oct 2004
    Northeast Oh-hi-Owe
    I'm not sure what your application is. But flooring contact cement works every well for steel and rubber... may work for your application.
    Oct 2004
    Akron, Ohio
    My company makes industrial adhesives (read sold by the drum or tote) that will bond HDPE to metal. These are heat activated so they must be dried then heated under pressure for 10-20 seconds to activate the bond. Email me and perhaps I can help you.
    -Christian D. Sokolowski
    True happiness is not having what you want but wanting what you have.
