Results 1 to 10 of 15
Thread: transformer question to all the electricians out there??
    Post transformer question to all the electricians out there??
    I have blown (a while ago) the transformer in my lathe a 440v in reducing to 110 v out.I removed the transformer and took it to r s components they supplied me with a 440v with instead of 110v single outlet two outlets of 55v making 110v out my friend an electrician says to simply join the two 55's to get 110 V out will blow the transformer.I went back to rs components and asked if I had been supplied the right transformer as this had two output terminals of 55v instead of one 110v I was told politely that they were unable to explain why as they did not have insurance to explain electrical wiring to customers so I would need to figure it out myself but the one supplied was basically fine. Can anyone explain this as I simply assume that joining the two output 55's will be fine am I wrong ?Alistair
    Nottingham, England
    No problem.
    You have the right transformer and the wrong electrician.
    John S.
    Sounds like the transformer they gave you has two 220v windings.. Input is 440v (+220 -220) output is (+55 -55) which has a potential of 110v. If you can hook up the transformer, test the A/C voltate between the two 55 volt secondary side terminals.
    -Adrian
    When in doubt, doubt your doubt.
    www.metalillness.com
    Nottingham, England
    Adrian.
    Not quite, he has a standrd 440 / 110 transformer for the UK it's one winding in, 440v and a 55-0-55 output.
    Just using the two 55's and ignoring the centre tapped 0 will give him 110v.
    John s.
    Oct 2004
    Prestatyn, North-Wales
    Lets hope you got the right transformer Alistair ....because i thought your lathe ran on 415 volts
    all the best.mark
    Aug 2004
    Sunny So Cal
    As stated, a voltage reading off the secondary will show you what you have...Shouldn't really be doing electrical without breakin out a confirmed good multimeter...JRouche
    [This message has been edited by JRouche (edited 05-09-2005).]
    Without showing us some idea of what connections are available on that transformer, it is unwise to believe any of us.
    That said, I think John S sounds closest....at least what he said makes sense.
    How many wires are there? Did they give you a diagram? Does it have a ratings plate? If so, can you post a pic?
    Connecting together any single wire from each of the 55 volt side will produce either of the following on the other two wires:
    110
    0
    Depending on the phase relationship of the two windings the output will be additive (110), or subtractive (0). If the load is nothing but a 110 lamp or volt meter it will be harmless to test it. I presume your 440 is single phase although it doesn't matter to the secondary windings.
    Certainly do not connect both wires from a single winding together as that well send you back to the store for another new one.
    dp
    You already have a great VOM (Voltage - Ohm - Mouth).
    High numbers of nerve endings in the tongue permit greater electrical sensitivity and the ability to measure voltage levels..
    I can tell the difference between 5v and 12v so I never need a meter to measure them.. I'm sure you can tell the difference between 55v and 110v with your tounge too.. No need for a meter.
    Coupla decades ago I had two crowns installed on adjacent teeth. One gold the other silver. I'm guessing one or the other may have been anodized aluminum, for all I know. Anyway, for the longest time after that second one was installed I'd get that electrical taste any time I bit hard enough to short them together. Bleh - hated that.
    dp
