Results 1 to 7 of 7
Thread: Tar roofing removal
    Sep 2004
    Post Tar roofing removal
    Whats the best way to remove old roofing tar roof patch from the top of a galvanized steel roof. Its on the old 1996 pickup camper i bought. Any good ideas short of just burning it to the ground, Thanx Madman
    Sep 2001
    Putty knife + kerosene + elbow grease.
    Oh, and rags. Plenty of rags.
    [This message has been edited by pgmrdan (edited 05-11-2005).]
    Oct 2001
    Pay someone else to do it. Someone that is desperate for money, like a local crack head.
    James Kilroy
    James Kilroy
    if it's that brittle stuff they use on mobilehomes, "roof coating"...a VERY high psi....3000+ may take a lot of it off. gotta keep a low angle and sorta peel it off.
    if it's "plastic cement"...roof tar....and not brittle ???...kero & scraper.
    roofers use a torch to soften the stuff and then scrape it off. they always have a fire ext handy !!!
    Deep in the Heart of Texas!
    I had to repair a motor home roof that someone had "fixed" with tar. What a pain! And no, I'm not on crack.
    I ended up using ice bags to make it brittle then chipping it off. The balance was removed with paint thinner and cleaned up with lacquer thinner.
    Dry ice should do it nicely.
    Paul G.
    Paul G.
    Sep 2004
    Imight have a big fire. Seriously i bought a 3000 psi subaru pressure washer. Its nice ill try it on the roof and get my nephew at 15 cash an hour to grunt. I was told the epdm rubber will blow off. Any ideas.
