Results 1 to 10 of 14
Thread: Pipe purchase
    Post Pipe purchase
    I am looking for some information. I need to buy 4" dia. schedule 40 steel pipe. Basically it brings water and air up the mountain so we can make snow in the winter. I need 2000' to 4000'. I am pricing out some projects and the final locations have not yet been determined.
    I am located near Ottawa Canada. Anywhere in Canada or the US would be prefered. I am just looking for contacts, i can do the leg work.
    Thanks in advance
    Rob
    Feb 2005
    Rob,
    Either ask your nearest fabrication shop where they buy theirs or look at the small tags attached to the fresh steel that's just arrived in their inventory.
    If you don't already have the documents needed for a business (license, tax ID number, etc.) get those before contacting the steel supplier.
    Pricing for a business buying the quantity you need is half of retail with free delivery.
    Barry Milton
    Barry Milton
    Dec 2002
    Friesland, Netherlands
    Rob,
    Is there any oil production in your area?
    If there is, you may be able to buy 'scrap' 3 1/2" production tubing. It'll come in 30 foot lengths with screw couplings, and you can construct your pipeline with a couple of large chain tongs. Might be a cheaper & quicker option.
    Just a thought,
    Ian
    All of the gear, no idea...
    Sep 2003
    Louisville, KY
    You're looking at 20-40,000 lbs. Talk to a plumbing supply wholesaler, you're buying enough that you should be able to get a decent price. For your application you will probably need tested pipe.
    Harry
    Mar 2004
    You have a pressure problem. To raise water 4000 ft you are going to need about 2000 psi to get the water up there unless you pump in stages of around 200-300 feet. Perhaps you are not going that high but you will need 1/2 psi per foot to overcome the head.
    [This message has been edited by Ted Coffey (edited 06-11-2005).]
    Hey guys,
    Barry:
    I will be buying the pipe through my work. It is not for ME but rather my place of employment. The kind of quatity i want to buy is bigger then the average machine shop and they don't stock too much of what i need.
    Ian:
    that is a good idea. Unfortunately i live above Syracuse N.Y. NOt much oil production here. The last batch i bought was from natural gas line instalations. All i had to do was peel back the plastic coating on the ends before welding.
    Harry:
    I live in the capital are of Canada. We don't have much industry here. The best i could get last year, from the local guys was still $2.50-$3.00/ft more expensive then what i got from my snowmaking supplier. The local guys wanted $8.00/ft and i got it from my snowmaking supplier for $6.00/ft and i think i could have gotten it cheaper still. Just something in his voice.
    Ted:
    No i am not pumping it up 4000 vertical feet. I am only going 700 vertical feet. I still have to pump the water from the lake to the mountain. I also have several lines that i run at different times. I have a total of 19 ski runs. 11 of them have snowmaking (pipe) on them. I would like to expand that number to 13 or 15, while replacing some of my air line. The air line only has 120 psi in it but i put through 1500 cfm. The water line runs about 450psi at the pump. 120psi at the top of the mountain.
    Rob
    Mar 2004
    SE, Michigan
    Sprkman.
    4" sch 40 weighs approx 10 lbs / foot.
    I pay 95 cents per lb, but that is less than 400 lb quantity.
    for the amount you are buying, you should get a good price, I would estimate that it should get down to at least .70 / lb, still you are looking at 10 - 20 tons, thus 15 to 30 grand for the whole shot.
    Jacob
    Jul 2002
    Find a Thomas Register and deal directly with the mill. I would think there is a mill in Sue St Marie, or at least Detroit.
    What is a thomas register?
    Dec 2002
    Thomas register = listing of all the manufacturers and companies in America, not sure if the world is in there too.
    I used to use it to find instrument manufacturers to get data on instruments I had to calibrate and commission. (engineers steal the paperwork)
    David
