make a smoke print of it.
take a small birthday candle, hold the item you want to copy at a 45 degree angle to the flame. Play some smoke on the area. Wait a minute or two and then put some scotch tape on it. When you pull the tape up you will have a positive. If you want a negative, put more smoke on then necessary and then make the one smoke print as normal and then put another piece of scotch tape against the first and then pull them apart and you will have the reverse.
Now if you put a "tiny" half drop of something tacky like varnish on the area you want to transfer it to, rub it with your finger till it's tacky, you can then position the tape over the tacky area and then stick it down and burnish it with the back of your finger nail. When you pull up the tape your image will be there. It works. It's how engravers copy one side of a gun to another side of the same gun. They also save copies of thier work by putting the tape on white paper.
Ray........
